2008 A/c Blower Motor Not working
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Oct 21, 2021.
  1. richard203
    richard203 Member
    279
    61
    SF
    Hi my blower motor not working put in a new one and still dont work. I tried to switch out a new blower motor module and still dont work. any 1 have any idea?
    52,847
    maybe the mfd?
  3. richard203
    richard203 Member
    279
    61
    SF
    you talking about the screen display?
    52,847
  5. richard203
    richard203 Member
    279
    61
    SF
    i think the screen display is working since when i change to interior air the a/c open up and then when i change bak to outside air the a/c close back up.
  6. bisco
    52,847
    each button stands alone. check to see if you are getting voltage at the board
  7. richard203
    richard203 Member
    279
    61
    SF
    So I think it’s my Amplifier Control Module I tried to test if there’s any voltage on the 3 pin wire that connect to the blower motor module and I’m not getting any voltage. Do I have to take out the dash to get to the ac amplifier?
  8. richard203
    richard203 Member
    279
    61
    SF
    I’ll use a techstream to active the blower motor to see if it active if it active then it’s the screen if it don’t work then it might be the amplifier or the wires
  9. bisco
    52,847
    Good luck, you’re above my pay grade now
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    You should have 12-14V on the large black wire and 0V (ground) at the white-black wire with the car in "ignition on" or "ready" modes. If you don't have power then you need to go back to the heater relay and (40A) heater fuse and test there.
    You'll want to have look at a wiring diagram in the service manual.
  11. richard203
    richard203 Member
    279
    61
    SF
    how do i check heater fuse is blown (40a) ? and for the heater relay theres two? R3 and R4 is heater relay do i check both?
  12. mr_guy_mann
    4,114
    2,012
    NJ-USA
    My diagram only shows one "HTR" relay (in the driver's side junction box).
    The manual says you should pull heater fuse H (40Amps - in the engine room junction box) and check resistance - less than 1 ohm. Me, I prefer to check for power where it's supposed to be (at the battery power terminal for the heater relay).
    You can use a multimeter to measure voltage level, but that won't stress a high current circuit like the heater power feed (you could have a high resistance somewhere in the circuit but not "see" it because there is no load to make voltage drop). A 12V "test light" will draw 1/4 to 1/2 amp and can determine if some power is present-(just use it only on circuits that can handle that current). For something like this heater supply, I might add some jumper wires to a halogen "sealed beam" headlight and connect one wire to the battery circuit terminal and the other jumper to ground (metal on the car body). Depending on how you wire it, some headlight bulbs will draw 5-8 Amps- which is a nice load for this circuit. Screenshot_20211022-231427.jpeg
  13. richard203
    richard203 Member
    279
    61
    SF
    How do you pull out the Heater Fuse (40A)? when I look at the cover it shows the 40A is inside the circle box and just copper metal?
  14. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    Inspect the 40 A fuse visually, and if it does not look intact, you will need to remove and replace the whole fusible link as a unit.
  15. mr_guy_mann
    4,114
    2,012
    NJ-USA
    The blower diagnostic write up in the manual doesn't mention that the 40amps fuse is part of the fusible link assembly. As mentioned you should first look at it closely. If it appears to be the same as the others next to it then it is probably ok .
    Now to be clear, when you have the car in ready mode and have the blower control switched "on", then you do NOT have 12-14V at the large black wire on the 3 wire connector to the blower control module?
    If that is true and the 40A fuse looks good then you need to test at the HTR relay (R2) at the driver's junction box - and/or the JB connectors to see why there is no power from the relay.
    First I would use a digital meter to determine which terminals are which at the relay and what voltages are present- or not. (Only after I KNOW which terminal is the Battery feed, then I might use a headlight bulb to test that circuit if needed. There are also low current circuits in the connector that trigger the relay coil that could be damaged by a high load like the bulb) Screenshot_20211024-112707.jpeg
  16. richard203
    richard203 Member
    279
    61
    SF
    where is that fuse box located? the website doesnt show where the location is but other fuse box it shows the location
  17. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Sorry, but I can't read your mind. I don't know which fuse box you are referring to when you say "the other" or "that".
    Near the very top of the Air Conditioning section in the service manual (pages AC-3 and AC-4) is the parts locator that shows where the driver's junction box and engine room junction box is.
  18. lexidium
    lexidium Active Member
    303
    144
    manchester
    Where did you buy the parts?
    Was it from Ebay used?
  19. richard203
    richard203 Member
    279
    61
    SF
    this fuse box
  20. richard203
    richard203 Member
    279
    61
    SF
    no everything is brand new I brought it from amazon
