2008 ac noise
Discussion in 'Gen 2 Prius Main Forum' started by amjohnson, Jun 4, 2017.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    Hello there I bought my 2008 Toyota Prius with 58000 miles on it a year ago. I drove it all through the summer here in Minnesota. And a week or so ago when I started using the AC I noticed when the fan speed is set low and it's just running on the electric motor I hear a hum inside the cabin I do not hear it when the Ice is on or not as much. I'll post a video of what it sounds like hopefully inside the cabin and out will you please let me know if this sounds normal thanks for your help
    52,773
    the a/c is quite noisy, a buzzing like sound. but if you feel it is much louder than last year, there could be an issue.
  3. amjohnson
    77
    US
  4. amjohnson
    77
    US
    Thank you finally figure out how to load the video could you take a listen and see if it's normal. there's like a hum and then when I move the camera and you can hear the buzz I can hear the same thing kind of inside but it's not as loud
    Data Daedalus likes this.
  5. bisco
    52,773
    that does sound a bit louder than normal. the buzz sounds right, but the whining doesn't. fan on low and nothing else running until the engine fires up near the end?
    Data Daedalus and valde3 like this.
  6. amjohnson
    77
    US
  7. bisco
    52,773
    and when you shut off the a/c, no sound?
  8. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
  9. amjohnson
    77
    US
    Correct no sound
  10. amjohnson
    77
    US
  11. amjohnson
    77
    US
  12. bisco
    52,773
    not sure, but a bad feeling you're going to need a compressor.
  13. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I have a 2008 Prius too. I use the A/C a lot, both during winter for demister purposes and in summer for cooling the cabin.
    In the 4 years I've owned my Prius, I've always been able to hear the compressor of my A/C. It makes a rather high pitched electric turbine sound when it's operating.
    I've actually arrived home in summer parked outside my home, left the propulsion system (and A/C) online, and stepped out of the vehicle to listen to it running. Outside of the vehicle, you'll definitely know it's online, as it sometimes sounds so loud, that when the ICE is off and your progressing along in vehicle induced EV mode or standing still, it's easy for a third party to believe that's your vehicle's ICE running.
    Yes, it can be that loud.
    When I turn mine on, I can hear it spooling up like a mini jet engine from inside the vehicle (I have exceptional hearing most of the time), and upon A/C shutdown, I can also clearly hear it spooling down - again like a mini jet engine. Now, I'm not sure if the loud whine I hear is coming from the A/C condenser cooling fan only, as there's more noise in summer than there is in colder weather - when it's not as loud.
    There is only one other weird thing my A/C does, while operational, and that's the relatively high pitched "dog bark" - sounds like a "Yiiip...!!!" sound, and it does that repeatedly - and has consistently done so for the 4 years I've owned the vehicle.
    Often in winter, the only warning I'll get when the A/C compressor is operating (as in when using the windscreen defogger), is that repetitive "yiiip...!!" sound. According to other Prius Chat forum users, it's not uncommon for some 2nd Gen Prii's A/Cs to make that sound - it's just another Prius II quirk.
    Ditto with my relatively noisy A/C compressor in summer - I just accepted it as being normal.
    However, in the last video above, I could hear a strange electric motor sound increasing in steps. My A/C definitely doesn't do that. It spools up smoothly to speed, not in steps.
    One more thing; there's an extra cooling fan in front of the vehicle that kicks in to cool The A/C condenser (looks like a radiator). I've heard that fan turning on and off independently as it's services are required.
    I've had my A/C checked and serviced in the last 12 months by Toyota; nothing unusual was detected or reported. I believe they also checked the refrigerant levels and replenished them. It seemed to work even better after the service check, which I did purely as a precaution and asked for myself - it wasn't malfunctioning.
    Hope this helps your diagnosis.
    iPhone ?
  14. amjohnson
    77
    US
    Do you think I should try adding refrigerant and oil? It just started a couple weeks ago thank you for all your help!
  15. Data Daedalus
    1,025
    1,185
    Wembley, London
    I'd say unless you're a refrigeration engineer with detailed information on the precise specifications for topping up the refrigerant on a Prius, I'd strongly suggest you have this done by a Toyota dealer / Toyota maintenance specialist who is 100% conversant with the Prius.
    I am aware that the Prius does not use standard refrigerant like other vehicles - particularly the oil, which is supposed to be specially formulated to operate in an electric compressor motor's high voltage environment....!! Other ordinary refrigerant oils will kill your compressor, I believe.
    iPhone ?
    #16 Data Daedalus, Jun 4, 2017
  16. amjohnson
    77
    US
  17. bisco
    52,773
    if you don't know what to do, don't do it. the compressor uses high voltage, and a mistake can run 4 figures.
    Data Daedalus and Raytheeagle like this.
  18. eman08
    eman08 Active Member
    360
    192
    US
    I can hear the A/C compressor while sitting in my house with the window open. Its quite normal actually esp if you have the fan on full blast and the temp dropped to Lo.
  19. amjohnson
    77
    US
    Just got a new used one put in on Saturday and it makes the same nosie:( but It blows cold!
