2008 and error codes p0102, p0113, p0446
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius_deep, Apr 5, 2021.
  1. prius_deep
    prius_deep Member
    105
    38
    road
    Looking for an answer [but will take hints]. Got a CEL and the following code p0102,p0113,p0446. Got the light the day after changing the motor oil [myself, because the oil change places sometime over filled, and other issues](it is not over filled).
    It[2008] runs same as always, good. But something is wrong for the light and code to show up. And yes I have looked up these code here on priuschat, but they don’t appear in my combination in other posts.
    I don’t think it’s the gas cap because car got filled 2-27-21, the issue would have shown up sooner.
    what does that blue * ,/ cloud mean on the far left of the display?
    Maybe the MAF has gone bad? P0102, P0113.
    I have cleared the codes and will see if they return. In the meantime, any thoughts?
  2. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
  3. prius_deep
    prius_deep Member
    105
    38
    road
    Since the original post the CEL has NOT returned
    but since I went to the stealership to pickup new washers for the 2016 [ the next for oil change ]
    I also picked a new gas cap for the ‘08[white]
    ‘new’ cap number held down with old cap
    so just because a new to you car has an item, it does not mean that it is right/correct [but never had any problems before or since clearing code] Thanks captain!
    But did go to youtube, of course; checked my vacuum lines, the one(s) that were ease to get to, and some of them are showing dry rot where the rubber meets the metal pipelines. It’s an ‘08, thanks captain!
    52,876
    captain, my captain!
  5. prius_deep
    prius_deep Member
    105
    38
    road
    toyota part 90910-12274
    don't understand Spanish but i found this
    the part is 90910-12274 it is a valve the car 04-09 uses to check the EVP system. if it is not working it will throw a P0446 code
    had toyota check my 08 after CE light returned [not gas cap after all].
    before CE returned
    after CE returned
    didn't know which part was bad; but the number is in estimate, so i checked on line to see what and where it was. it is the valve in the video.
    my looks really rusty,
    anyway after having toyota check the car, they didn't have the part so they special ordered it. total job estimate around $490, call it $500!
    this guy in the video makes it look simple, but his problem might be something else because in the description he has the word 'Gasolina'
    my appointment is for next weekend, was going to cancel it, but because [ you know special order and all] and the fact that my bracket is all rusted i think i am going to go though with it. would have saved $400
    anyway this is to help other.
    and for those who under Spanish what is he saying in the description is wrong with the car?
    ebay item 333757512818 looks like my , rusted bracket .
    ebay item 124407353109 to see where part is located
