2008 - BRAKE, ABS, VSC and Orange Circle with Triangle light on, with steady beep
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yossi, Apr 14, 2022.
  1. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Some systems begin to come into operation as soon as you open the car door, so the ECU will have time to detect a low voltage error before you turn on the START button. The converter is quite reliable during operation. When it burns out, then this is a specific failure, and there will no longer be 13-14V in the system.
  2. Ntelas
    Ntelas New Member
    Greece
    Here is a picture I took while this was going on . Cheap obd2 reader didn’t show any engine codes.
  3. MAX2
    MAX2 Senior Member
    1,436
    487
    101
  4. Ntelas
    Ntelas New Member
    Greece
  5. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The converter is located in the inverter housing at the bottom.
    The relay unit is a large black box with fuses and relays under the hood.
    Auto electrician skills are necessary. Without experience, of course, it is difficult.
    Ntelas likes this.
