2008 Brake and ABS light on and off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EdwardFlorida, Sep 1, 2020.
  1. EdwardFlorida
    EdwardFlorida Junior Member
    2008 prius ABS and brake light come on and off. When off Brake function is normal, when on Brake performance poor as if no power assist.
  2. EdwardFlorida
    also if I pump the brake a couple of times the lights go off and brakes are normal again
    52,891
    probably the brake actuator. specific codes and sub codes will help nail it down.
    is the fluid level correct?
  4. EdwardFlorida
    Fluid level OK I will try to get codes. May go a several mile normal then come on. Stays on maybe 30 second then goes off again
  5. bisco
    52,891
    make sure the battery connections are clean and tight, especially neg to body
