2008 Camry Hybrid Issues
Discussion in 'Other Cars' started by Joe2008Camry, Dec 27, 2020.
  1. Joe2008Camry
    Joe2008Camry New Member
    Leonardtown MD
    Camry 2008 White 223,763K Miles Yesterday Morning I Got The Red Triangle Of Death Vsc Light Check Engine Light Abs Light And The Brake Light Tire Light And The Check Hybrid System Check Vsc System And Maintenance Required Light. I Had It Sit For 3 Weeks. I Tired To Drive It To Toyota But About Half A Mile The Car Ran Out Of Gas. So I Called Triple A To Tow It Toyota Dealership. And They Said Bad Inverter Bad 12V Bad Gas Tank Bad Hybrid Battery Needs A Oil Change Low Coolant Fluid Bad Regenerative Breaking And Bad A Battery Sensor For One Of The Tires. They Still Have My Car On There Lot. Here Are The Codes They Provided For Me And The Battery Voltages. Any Advice Would Be Helpful. Thanks, Joe.
    P0A7A
    P3191
    P3193
    P0A0F
    P0AFA
    P0A7F
    P0A80
    P3013
    C1241
    C1259
    C1310
    C2124
    B1424
    12V 9.03 OFF 9.45 ON
    BB1 17.25
    BB2 17.17
    BB3 13.33
    BB4 17.07
    BB5 17.09
    BB6 17.02
    BB7 17.21
    BB8 17.00
    BB9 17.07
    BB10 17.20
    BB11 17.16
    BB12 17.10
    BB13 17.10
    BB14 16.99
    BB15 17.00
    BB16 0.77
    BB17 -24.98
    #1 Joe2008Camry, Dec 27, 2020
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    Definitely some out if spec readings on bb3, bb16, and 17.
    The difference between blocks should be 0.5v or less.
    P3013 says block 13 is bad as well.
    Maybe be time to let this car go.
    New battery is over $3,000.
  3. Joe2008Camry
    Leonardtown MD
    Wouldn’t a new car cost more then fixing it? I want to know what else to do keep the car bc I need a new 12 a hybrid battery and inverter and a bad sensor on a tire and regenerative breaking and I think gas tank I had car for 13 years
    #3 Joe2008Camry, Dec 27, 2020
