2008 Drain bad fuel from the tank
Discussion in 'Gen 2 Prius Technical Discussion' started by JohnStef, Aug 16, 2018.
  1. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Recently purchased a 2008 Prius with a full tank of gas, the engine runs pretty smooth but has a noticeable tapping sound under light to heavy load. But it goes away under a no load condition.
    I would like to remove the fuel line from the fuel rail and pump the gas out and replace with fresh. I need some guidance on how to energize the fuel pump.
  2. JC91006
    16,936
    8,647
    I suspect that car burns a lot of oil and it's not related to your gas
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    I've answered this question not too long ago.
    Not sure the best way for you to search for it.
    Basically I identified where to apply 12v to the fuel pump under the back seat.
    I remember mentioning also that the cover lid was very sharp. Easy to cut yourself.
  4. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Raytheeagle and JohnStef like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    If it’s got close to 200000 miles it’s probably a blown bottom end on the motor, many many posters here have ruined there engines running it low or out of oil. Damage stArts as loud tap which is piston bearing and if continued to drive turns into loud knock. Hilarity ensues when piston #2 makes hasty exit out the side of the block.
    Cause Bad gas=engine no workee much less tappy
  6. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Your way removes the rear seat, pulls the fuel pump cover and applies power to the pump, No way to apply power thru a relay?
    One idea I had was to pull the main relay block and pierce the correct wire with 12v, but I don't know which one this is and if this current will go elsewhere and blow something.
    #6 JohnStef, Aug 16, 2018
  7. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Removing the lower portion of the rear seat is so simple you don't need tools. Simply pull upwards.
    And from there it is a very short time to unbolt lid
    and apply power.
    DLC82SV likes this.
  8. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Thank you Eric, I should have done this a week ago!
    DLC82SV likes this.
  9. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    And once again I'll say that the lid is very sharp! As in razor sharp. Why so sharp? I have no idea.
    Every time I tell myself, "I don't need gloves THIS time. I'm sure I'll be careful enough THIS time and not get cut."
    WRONG!
    Then I just have to grab some extra towels so I don't bleed all over the customer's car.
    Raytheeagle likes this.
  10. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Finally got back to the Fuel Pump
    Eric do I have this right?
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Then why not add some quality fuel conditioner/treatment and use up the tank? A noticeable tapping sound is usually from a mechanical source (valves typically).
    edthefox5 likes this.
  12. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Eric I just deciphered an electrical diagram for the Prius Gen 2 and the picture I have is correct, happy. Now I will proceed.
  13. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    I put 2 cans of SeaFoam in already, I don't know what effect this has on Octane though.
  14. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I can't seem to get the photo.
    Does it match up with my kinda lame description?
  15. fotomoto
    5,639
    3,815
    So. Texas
    I think you way over medicated with 2 cans (see directions) but if boosting octane to reduce ping is your goal, there are additives for that at auto parts stores.
  16. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    How did you conclude the issues you had was related to fuel system?
  17. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Yes it does Eric, you callout in the
    Diesel container & the smell test thread noted above:
    There are 2 rows of 4 pins.
    I'll arbitrarily call the position on the far left "1", position on far right "4"
    Power can be applied to the pins in row "3".
    For those 2 pins, apply positive to the pin in the row nearer the connector tab, negative to the pin in the row farther from the tab.
    So my data comes from Toyota and they. yours and theirs, both agree. I will apply a tired 12v LiPo battery tonight, under load it will drop to 11.2v, if I see fuel flow, then i will know I have it right and then apply a 12.6V portable lead acid battery. This is a little more complex than needed, but I have these things in my garage and I don't want to destroy stuff, I'm in "caution" mode.
  18. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    trial and error
    The car ran rough intermittently and the tap tap tap sound was louder than it is now. My 1st thought was sticky lifter. The Prius mechanic I consulted said, No, 9 times out of 10 it is bad combustion. It had 2 bad coils, they had black soot on them and one of them threw a coil pack code. I replaced them with used parts, I have no codes related to bad coil packs. So I am running down every method to improve combustion, my last stop is the old gas replacement.
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Car has solid Lifters.
  20. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Ed what does this mean?
