2008 failing battery - worth it?
Discussion in 'Gen 2 Prius Main Forum' started by Mags6, Aug 27, 2022.
  1. Mags6
    Mags6 New Member
    St. Petersburg, Florida
    I found a 2008 for sell but they were very transparent and the battery is failing. It had the red triangle and requires to clear code for it to start. But after it runs ok. Just a bit rough when switching.
    Wondering if worth it to buy at a good cash price and replace the battery ?
    and what would a value be on one knowing the battery has to be replaced?
    Even possible to drive it a bit before ?
    it’s in fine condition otherwise. Dealer said they also replaced cool inverter.
    Considering. As I was wanting to get into one for a low cash price. Under 5-6k. But ya this one. Will have to fix.
  2. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    Do you a or a friend or family member like to work on cars and electronics? PriusChat can help you keep the battery going for a low price if you have someone to do the work on the battery and other problems that come up. But if you don't have that and plan on an established auto shop or Toyota Stealership doing the work it will be a money loser and not worth it. But if you enjoy taking things apart or someone close to you does, used replacement modules only cost $35 and sometimes you only need one to repair the pack.
    52,774
    welcome!
    couple things:
    you don't know if the battery is the problem until you read the trouble codes
    don't believe anything the dealer tells you
    get a carfax and check the maintenance history at toyota.com/owners
    new batteries are in short supply, rebuilt batteries are mostly iffy
    how many miles on her?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    That's a possibility. Why not check with Tampa Hybrids? New and rebuilt aren't the only options. There's also a used battery option. You can get one that's near new and been rebalanced with all original modules for less than new. If you're a DIYer, they aren't hard to replace yourself.
  5. Mags6
    Mags6 New Member
    got 188,982 miles
    And you’re right, I am going to take it for a full diagnostic tomorrow before I buy. See all codes and make sure what I’m getting into.
    I was thinking to offer $2000
    seem right if it is just the battery ?
    there are 2 companies I looked at for battery. Greentec which is nearby, and greenbean.
    It’s feasible.
  6. Mags6
    Mags6 New Member
    Tampa hybrids seemed to just sell higher priced used Prius, similar year, that have varying degrees of replaced batteries in them. For 8-9k
    I can essentially create this myself. Stay under 5k. See my other reply. There is a company in Clearwater that replaces batteries.
  7. Mags6
    Mags6 New Member
    No I have been looking at a hybrid battery place nearby called GreenTec and greenbean.
  8. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    It is a 2008 how much are you talking for the car I wouldn't look at a 2007 today The rear spoilers broke but the hatch isn't damaged The battery is definitely is bad Gray interior the rear bumper cover has been replaced so it's black primer and other than that the car looks in pretty decent shape I told the guy $600 and some paperwork issues and the parts just aren't flying off the car it's sitting in his yard and I'll put a battery in it no problem.
  9. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    A new battery will run you $2,200 and your time to replace......4 hours.
    how are the CV boots? Suspension? ABS Sensor? How is the paint? INterior?all service records? I'm a heavy DIY guy and If the rest of the car was in great shape I'd offer $2K max.... Has it been in Florida its whole life? Does the MFD screen have sunburst damage? Thats $400 to fix. new suspension $600, CV axles and tranny fluid. $300. And these are just part prices...not labor.
    Mags6 likes this.
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    You may want to check some of the many threads here about those and other rebuilt batteries before you pull the trigger on the rebuilt option.
    No, you can also buy a used battery with original, matched modules there that's been balanced and will be more reliable than a cobbled up one made from various old modules. There may be other hybrids shops on your side of the bay that can do the same.
    Just trying to save you some grief later on. ;)
    Moving Right Along and Mags6 like this.
  11. Mags6
    Mags6 New Member
    Just took it in for a diagnostic
  12. Tombukt2
    13,809
    2,504
    Durham NC
    Most any of these cars you find the batteries in them are going to be 20 plus years old so it's going to be time and almost any one of these you pick up everyone I see for sale either at a dealership or in somebody's yard all they can do is stand and go well it's driving fine and I go well the battery's 20 years old driving fine or not that'd be like saying your tires have 80,000 mi on them but I still want 12 grand for the car not with those old nice person tires on it you don't but such is life that is the silliness of human beings that is why some of these cars are selling for 12 grand people pay 12 grand form and by the time they get home next week all the dash lights are on yeah the car's been perfect condition it's a cream puff but it's still 20 years old. Point blank so you're going to have all the 20 plus year old problems. Whether you like that or not whether the person you're buying from the car realizes that or not of course they don't because they're looking for $4,000 more dollars than they would have got 14 months ago That's all they see
    Mags6 likes this.
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    Oh boy! That looks like a real fixer upper.
    Mags6 likes this.
  14. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    I agree with what Jerry said. It’s a project car. Great if you’re a mechanic and want something to work on; bad if you want reliable transportation.
    Mags6 likes this.
  15. Mags6
    Mags6 New Member
    Ya I decided to walk away. Will keep looking for my perfect match lol.
    I don’t mind replacing a battery. But that’s too much. Sigh
    bisco, ColoradoCrow and jerrymildred like this.
  16. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    Sounds like a MONEY PIT Prius=
  17. Mags6
    Mags6 New Member
    Found my match.
    She’s not perfect but I think she’s tough. Lol
    2008
  18. AzusaPrius
    AzusaPrius Senior Member
    2,251
    941
    Well glad you didnt jump on that first one but the second can also be a pain.
    The sad part is most people who have never had a prius think their basic code reader will tell them everything.
    The sadder part is the seller can always reset codes and/or disconnect the 12v.
    The saddest part...you find out you have issues and codes sometime between 50-1,250 miles after you paid for the car you thought had no expensive codes.
    I would advise anyone looking to purchase a prius to buy a Carista ODB adapter.
    Download Dr. Prius app.
    Make sure the car has not been reset recently and if it has then have the seller drive it until it can pass the smog, since they have to supply the buyer with a smog test anyway.
    Once that is done double check it hasnt been reset again and check for codes.
    Buyer beware...
