2008 Gen 2 O2 Measurement Mystery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert John, Oct 28, 2024.
  1. Robert John
    Robert John Junior Member
    64
    Montreal, QC
    2008 Prius (172,000 kms) periodically triggered PO420, no exhaust leaks, good mileage, does consume some (synthetic) oil. PO420 became more frequent (every time I drove the car) so I changed the cat pair + O2 sensor (although ‘old’ O2 sensor had only 35,000 kms, and never provoked any O2 codes). Considered changing A/F sensor, but that’s WAY too difficult. As soon as cat was changed, car started triggering PO136 & PO139 (no other codes, good mileage, no detectable exhaust leaks). Dang!
    Scanner reads voltage on new O2 sensor as 0.8V (within spec. according to shop manual). Resistance measured on ‘new’ O2 sensor (cold, Pins 1 & 2) is 13 ohms, compared to ‘old’ O2 sensor’s 16 ohms (both within spec according to shop manual). But… I cannot get any resistance across Pins 1 & 4 (the ‘heater’ ?) on either the ‘new’ or ‘old’ O2 sensor (cold): should read 10k ohms or higher according to shop manual: two different DVDMs read both as an open circuit. Unusual for both ‘new’ & ‘old’ O2 sensors to be bad… given ‘old’ sensor never triggered O2 codes before the cat was changed.
    Does anyone have any insight as to what’s happening here, or what I’m not seeing or doing wrong?
    Thanks!
  2. Brian1954
    Brian1954 Senior Member
    2,670
    1,068
    South Central PA, USA
    The new O2 sensor that you installed, is it OEM or an aftermarket?
  3. Robert John
    64
    Montreal, QC
    Aftermarket. When the original Bank 1 Sensor 2 went south (approx. 35,000 kms ago) I bought a pair thinking I'd replace both O2s in the bank. But unlike other cars I've had, I discovered that Bank 1 Sensor 1 is not an O2 sensor, but an A/F sensor. So when I changed the cat, I put-in the new sensor I'd never used. What puzzles me is the 'old' O2 sensor (that never triggered a DTC code) I pulled when I changed the cat has no resistance across pin 1 & 4... just like the 'new' sensor. I have to assume both can't be 'bad' and I'm doing something wrong.
    Q: Does the 02 sensor have to be at operating temperature to measure the resistance of its heater? Nothing about this in the manual, except that the sensor circuit (pin 1 & 2) has to be measured at 20 degrees F. Also, a PO136 is supposed to be a voltage issue (reads OK at 0.8V), and PO139 is supposed to be a problem with the sensor's response time. I'm flummoxed ;-)
    Thanks!
  4. Brian1954
    2,670
    1,068
    Sometimes, it pays to buy OEM. Just saying.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Pins 1 & 2 ARE the heater, that's all you can measure. 3 & 4 are for the sensing element, that's where voltage is produced under the proper conditions.
    The ECM doesn't like something about how the new sensor works.
    The short form is I would install a genuine Toyota or Denso sensor from a reputable source (not amazon or ebay).
    Brian1954 likes this.
  6. Robert John
    64
    Montreal, QC
    Thanks for the pin info. Scanner says I'm getting 0.8V (hot) from the sensor, and voltmeter reads 9.0 ohms (cold) across Pins 1&2 (heater) which is also within spec. according to the shop manual. But I'm not getting any resistance across Pins 1&4 (on either sensor) - which the shop manual says should be 10K ohms.
    You mentioned Pins 3&4 is the sensing element, but I can't find info on any mention or measurement for those two pins in the manual.
    Q1: Do you know what voltage I should be getting across Pins 3&4?
    Q2: Does Toyota make their own 02 sensors, or do they use Denso?
    I think I got the pair of 02 sensors I have at RockAuto... just checked... RockAuto doesn't have Toyota or Denso O2 or A/F sensors, so the two I have aren't OEM.
    Q3: What brand(s) would be a qualified OEM replacement?
    Otherwise, I'll have to bite-the-bullet and go to (gasp!) the dealer ;-)
    Thanks again for the info - much appreciated!
  7. mr_guy_mann
    4,113
    2,011
    NJ-USA
    So, when the downstream O2 sensor is installed (connected) and the engine is running & fully warm- you should see the same voltage at pins 3 & 4 that is on the scantool. 0-1.0V range, typically around 700mV at steady throttle with a healthy cat.
    I don't know where your service info is from, but I have never heard of (or tested for) continuity between the heater circuit and the signal circuit.
    The signal circuit is very sensitive and 10k resistance is essentially a dead short for it.
    Denso makes A/F and O2 for Toyota. Those are the brands I would use (maybe NTK if neither was available).
  8. Robert John
    64
    Montreal, QC
    OK, I'll look for a Denso or NTK O2 sensor... may have to go to the dealer. Thanks for the advice!
    BTW: I get 800 mv on my scan tool (warm, running), and found the resistance measurement info for the O2 sensor on page EC-51 in the Repair Manual for Gen 2 Prius
  9. mr_guy_mann
    4,113
    2,011
    NJ-USA
    OK, in that context "10k or higher" means that there should really be no continuity between the two circuits (aka - infinite resistance or "O L").
    Again, it's not a test that I have ever used. I'll check heater resistance and current, or signal voltage. If there's "bleed through" between the heater and signal, that will show up as high or low signal voltage.
  10. Robert John
    64
    Montreal, QC
    OK, so I'll assume the resistance reading across Pins 1 & 4 is alright (although I don't know what the reading on a 'failed' heater should be). Since I'm getting 9.0 ohms (cold) from both new downstream O2 sensors I have, I'll have to try & read the voltage across pins 1 & 2 when parked in a heated garage somewhere (20 degrees C / 68 degrees F) ...we won't have that kind of temperature here until late May next year ;-) Otherwise, it's off to the dealer.
  11. mr_guy_mann
    4,113
    2,011
    NJ-USA
    I would not be that concerned about the heater circuits on pins 1 & 2. If the sensor is putting out 800 mV then it's getting "hot enough" to work.
    My first concern for this type of fault code is the sensor a known good brand? I'm talking about both the Air - Fuel and the oxygen sensors. If either is not up to OE spec then that can throw off the self-test results.
