2008 Gen 2 owner stumped by key fob
Discussion in 'Gen 2 Prius Main Forum' started by MrFixITsPrius, May 9, 2022.
  1. MrFixITsPrius
    MrFixITsPrius New Member
    Indiana
    This past weekend I purchased an 08 Prius as a first car for my daughter. It came with only one key fob (with the silver Toyota logo). The seller said its battery was dead and that's why the key needed to be placed into the key slot in order to start the car, and why it's proximity features, and lock/unlock functionality weren't working. I replaced the 2032 battery, but to no avail. (Note that the car *does* have the black touch buttons on the driver, passenger and trunk doors. It also has the button directly below the steering column - and it is set it the *out* position.). I've done quite a bit of online reading and YouTube watching, and am stumped as to why my key fob isn't functioning properly? I'm looking for help on what to do to get it's *smart* features working properly for my daughter. Am I missing something? I've seen lots of content related to programming a new OEM key fob, but nothing about what to do in my situation. I'm hoping the info is out there and that I'm just missing it. Any and all help greatly appreciated. :)
  2. Kaptainkid1
    Kaptainkid1 Active Member
    308
    248
    Los Angeles
    Well if it was a dead battery then all the functionality would return once the battery powers up the SKS fob. I would pulled key out the fob and find out if the Key opens the driver's door. Secondly the SKS fob does have a magnetic keycode only for your Prius. So I feel the Keyfob does belong to your car.
    Also on the Fob is a small red light that comes on every time you hit any of the buttons. Is your red light coming on? It's on the upper right corner. Then you know unit cycling. Fob could be broken as well.
    SM-A526U ?
  3. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    It sounds like (one of) the previous owner(s) took the cheap way out when a new key fob was required – they bought a used SKS key fob and only linked the RFID code to the car.
    Unfortunately for you, to get all the functions working it will require a delete and re-add of the current key. This can only be done by the dealer or an accredited auto locksmith as an authentication seed code is required. There may be another option for doing it yourself if you have access to a copy of Techstream that can access the immobilizer functions and you can obtain the required seed code. I believe there might be one or two threads with details of this process.
  4. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    So now it's manual key only ? To unlock car to drive ? Boy I'd be happy . Personally. As a general rule I don't buy these for kids or car newbies. Old Yaris or Corolla First. For my sanity and peace. Never get Dad calls in those unless it's accident.
