2008 Gen 2 triangle of death, engine turns off, battery and other symbols light up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jon Good, Oct 27, 2022.
  1. Jon Good
    Jon Good New Member
    Seattle
    I’ve been driving it for a few weeks now I still haven’t changed out the inverter coolant pump.. like I said very little movement no movement in the reserve tank but the pump is vibrating. What I did was happened to notice the engine coolant reserve tank was nearly dry. I filled that up and I haven’t had any warning lights since. Still plan on changing out the inverter coolant pump though.
  2. dolj
    dolj Senior Member
    8,395
    4,276
    Wellington, New Zealand
    It would be a good idea to actually check the level in the radiator filler neck. That's the level that matters for the engine cooling.
