2008 getting P0a93 after inverter pump replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jewellrunner, Jul 20, 2020.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Also after market pumps don’t seem to last long you must use the high quality
    OEM Denso pump. As far as yours clogging no idea as you never mentioned miles on the car.
    Have seen a few very clogged coolant loops on this site that is caused by never replacing the inverter coolant there’s numerous very small coolant channels through a large aluminum coolant system.
    I hope you flushed the coolant and bled the system that will help with any clogging.
  2. sissonsk
    sissonsk Junior Member
    Houston
    I can't figure out how to start a new thread.
  3. edthefox5
    10,096
    4,840
    Clearwater, Florida
    When you go to the main page and it shows all the G2 forums select the forum you want to start a new thread in then after selecting that forum you will see a blue box on the right hand side that says: POST NEW THREAD. click on that.
    Also in the top of the main page theirs a blue line that says:
    search forums
    click on it put the title word in the search box and then at the bottom select search.
    Like: INVERTER PUMP Then you will see hundreds of inverter pump posts for instance.
  4. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    When you click into the search box, click the "More..." button in the popup window which will take you the Advance Search option. From here you can select to search only the Gen 2 forums and their children to limit the hundreds of result to only those about the Gen 2.
  5. sissonsk
    Houston
    Thank you.
