2008 head gasket replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by warlok, May 20, 2026.
  1. warlok
    warlok Junior Member
    25
    Casa Grande, AZ
    My 2008 Prius with 125k miles is running fine but is pressurizing the cooling system after a prolonged overheating event where the belt snapped. The fluid color radiator test shows bad head gasket (fluid turned green). Looking for advise on what to do while replacing the head gasket. Planning to grab the Mahle or Felpro gasket set and doing to work myself. I can lap/flatten the head at my job if there is any warp. Do you think it is likely that there would be a crack in the head? I'm trying to save some cash with everything else I have going on. To have the head pressure tested and resurfaced is about $200. Another $250-300 for valve job if needed. A rebuilt head online, shipped is about $615. Another $200 for the gasket set, water pump, thermostat, etc. What do you think is my best option:
    $200 for gasket set, water pump, and thermostat. Lap my head and hope for the best with no cracks in head.
    $500-800 for rebuilding my head and gasket/pump/thermostat. If it's cracked, I need option 3 anyway..
    $815 for rebuilt head gasket/pump/thermostat.
  2. PrimalPrius
    PrimalPrius Member
    138
    America
    I relatively recently replaced the gasket on a 2009 and I FAILED (coolant still leaks into oil). One thing I would do differently is take the head to a shop for resurfacing. I got quoted "about $60-70".
    I personally would not buy a refurbished head unless it comes with both cams, otherwise getting correct valve clearance could become an expensive hassle.
  3. PrimalPrius
    PrimalPrius Member
    138
    America
    The head bolt socket is NOT triple-square nor XZN. It is dual hex aka bi-hex size 8mm and you need one that is longer than a typical bit. Performance Tool W83184 Extra-Long Double Hex Head Bolt Sockets for Toyota Engines, 2 Piece, 8mm and 10mm Sizes, S2 Steel worked great. $18 regular price from Walmart. It was shipped, I don't think stores carry it, but I'm not sure.
    I used the Felpro the 1st time. The gasket looked good and I don't suspect the gasket at all. This time I ordered a Mahle for no other reason than that it shipped from the same Rockauto warehouse as stuff for other vehicles. The Mahle seemed to resemble the head gasket that was on the car (I don't know if factory original) more in some details, but I have not compared. I don't suspect that the gasket had anything to do with what went wrong.
    The timing chain cover has a water passage, so pay attention to get sealant everywhere it's supposed to go.
    I didn't touch the inverter other than set the inverter tank aside. Moving the inverter housing would have made accessing stuff on that end of the head a bit easier but was not necessary. 90 degree pliers helped with hose clamps.
    #3 PrimalPrius, May 20, 2026
  4. PrimalPrius
    PrimalPrius Member
    138
    America
    I have had my 2009 about 60k miles and I'm not aware of any overheating during my ownership.
    (Only unusual engine issue I had was intermittent misfire caused by a faulty NGK spark plug from rockauto, so not supposed to be a fake like one can supposedly easily get from ebay, amamazon, etc).
    I plan to definitely check the head much more carefully for cracks, because I felt that the procedure went well but it didn't fix the problem.
    My cooling system holds 15 psi for days, but as soon as combustion forces are present, coolant mixes into oil, even on a completely cold engine, so coolant is not yet at anywhere near radiator cap pressure.
  5. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    You should be able to get a one NZ head w cams valves adjusted and set etc about 400. I did same w 1zz the guy said he could 1nz for Prius . He did a bang-up job on the ones easy look like a brand new head and I'm sure the Prius will be saying that was delivered .!
  6. warlok
    25
    Casa Grande, AZ
    PrimalPrius - If I get the reman head, it does come with cams installed, resurfaced, ready to go for $615 shipped to me. But I think I'm gonna pull mine and have it PT and resurfaced. Hopefully that's all I need.
    And I was looking at the Performance Tool W83184 and places say it is a triple square, not double hex..?? More Information for PERFORMANCE TOOL W83184 Is that the right one?
    I have not gotten any coolant in the oil, just pressurizing the cooling system.
    Tombukt2 - $615 was the cheapest I could find online. Can't find any locally in PHX. Toyota Echo Prius Yaris Scion Previa 1.5 DOHC XA XB VVTI
    I'm planning to start disassembly this weekend.
  7. PrimalPrius
    PrimalPrius Member
    138
    America
    Yep, Performance Tool W83184 is correct. And yep Rockauto has it incorrectly described as "triple square".
  8. PrimalPrius
    PrimalPrius Member
    138
    America
    Rocauto also has this wrong: "Use the 8mm on models up to 2006, and the 10mm on models 2007 to current", at least when it comes to Prius.
  9. PrimalPrius
    PrimalPrius Member
    138
    America
    Just in case, your parts list didn't mention head bolts (but could have been included under "etc")... The head bolts are torque-to-yield and are not to be reused.
  10. warlok
    25
    Casa Grande, AZ
    Yes, getting head bolts as well. About to place the order from Rock auto. Felpro head gasket kit and head bolt set, Aisin water pump with gasket, Motorad failsafe thermostat and seal, PT head bolt socket set. Sound about right?
  11. PrimalPrius
    PrimalPrius Member
    138
    America
    BTW, the link lists both Prius and other models for the same head.
    Prius camshafts (or at least intake for sure, probably exhaust too) should be different from the rest.
    #11 PrimalPrius, May 21, 2026
  12. warlok
    25
    Casa Grande, AZ
    OK. I'll keep that in mind if mine is no good and I have to replace the head. Fingers crossed mine isn't cracked.
  13. PrimalPrius
    PrimalPrius Member
    138
    America
    I'm curious what people here think about Prius timing chain replacement at 125k?
    Personally would just inspsect, including guides and tensioner, and let it ride if it looks good (unless I thought that what's in there is a no-name ebay special, which is probably very unlikely).
    Depends on what "prolonged overheating" means... Maybe replace guides as a precaution?
    I recall hearing somewhere that if the 3 timing marks on a Toyota chain have disappeared, it has overheated? Any truth to that or is it an old wives' tale?
  14. warlok
    25
    Casa Grande, AZ
    I plan to just take a look at the timing chain when I get it apart. Doesn't seem like a high failure part that I've seen.
    "Prolonged overheat" means when the belt driving the water pump decided to leave the car on it's own (I didn't know that happened) and in the situation I didn't see the high temp notification that either didn't show up or disappeared quickly, I gingerly drove home about 40 miles with no coolant flow. Clearly running very hot. With the belt replaced it runs nice and cool but pressurizes.
  15. PrimalPrius
    PrimalPrius Member
    138
    America
    Yeah, no vehicle should be sold without an honest oil pressure and coolant temp gauge.
    By honest I mean one that hasn't been "Nerfed" so that it reads outside of normal range only after it's already too late.
    warlok likes this.
  16. PrimalPrius
    PrimalPrius Member
    138
    America
    "Heat sensitive paint" supposedly. (I guess all paint is "heat sensitive" at a high enough temp lol). This is supposedly on purpose on Toyota chains. I have no idea what years, models, engines that's supposed to apply to.
    Edit: ChatGPT says I got duped. No such thing supposedly.
    #16 PrimalPrius, May 23, 2026
