2008 Headlight Replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaryGeorge, Aug 13, 2019.
  1. MaryGeorge
    MaryGeorge New Member
    Seattle
    My driver side light is out. I’ve read to switch the two to see if it’s the computer. Is that a good way to approach this? Also, how do I tell if it’s HID or halogen?
  2. RobertK
    RobertK Member
    128
    Norfolk, VA
    Does your car have fog lights? If so, you have HID headlights. If not, you have halogen headlights.
    Given that your have a 2008, it's probably the bulb. I'd replace the bulb first rather than do the work of changing the bulb multiple times. If you replace the bulb and it still doesn't work you can try your old bulb in the other side. That will tell you if your old bulb is the problem.
    You might consider replacing both bulbs at the same time, since the other bulb will probably fail soon given its age.
    If the car has HID headlights it is important that you get a genuine HID bulb from a known manufacturer. A counterfeit bulb will not last very long. Be sure to never touch the glass of the new bulb when handling it.
    MaryGeorge likes this.
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    That's a 99% guarantee, but not 100%. Fog lights were a dealer-installed accessory on cars with halogen headlights. So unless one has owned the car from new, the presence of fog lights does not guarantee that the car has HIDs.
  4. MaryGeorge
    Seattle
    I don’t have fog lights, and I’m the third owner. Is there any way to look this up using the VIN number? Just wondering...
  5. egg_salad
    545
    426
    Las Vegas, NV
    If you don't have fog lights, you can be 99.99999999% certain that you have halogen headlights.
    #5 egg_salad, Aug 15, 2019
  6. Patrick Wong
    18,210
    6,517
    Besides the presence of factory installed fog lights, another way to determine the car has HID bulbs is that yellow warning labels which warn of high voltage can be found adjacent to the headlight assemblies.
    At this point it is pretty much guaranteed your car has halogen bulbs, hence just buy a bulb or two, and replace one or both depending if you are a proactive person.
    egg_salad likes this.
  7. MaryGeorge
    Seattle
    Well, even though I’ve fixed headlights in my the past (Toyota 4x4 and VW Passat), I decided to take it somewhere this time. One place, that doesn’t specialize in Toyotas, quoted me $700!!! The other place quoted me $300 but ended up charging me $150. It really does pay to go to a good specialist! Oh, and the bulb was halogen
  8. Stevewoods
    Stevewoods Senior Member
    664
    1,252
    where I am
    Never have agreed with the "logic" of "might as well replace both because the other one will go out soon."
    Over the years never found that to be true in household lights -- kitchen light bank, six lights, all installed at same time in 2009-- two have burned out and been replaced, the other four are the original.
    My Prius, passenger side halogen replaced for the first time ever 18 months ago, driver's side still fine. Rear passenger tail light bulb replaced around two years ago, driver's rear bulb still fine. Camry, driver's headlight replaced two years ago, passenger side still fine...
    Seems logical to replace at same time, but in practice...
    Skibob and MaryGeorge like this.
  9. Stevewoods
    664
    1,252
    where I am
    O.K. This has to be a curse.
    My passenger side just went out! Not even two years old. Still the original driver's side. Struggled to replace it without pulling too much apart, but, I guess as Mick Jagger says, "What a drag it is getting old," as I could not pull the connector off the plug no matter how much I tried. So, ended up having to take half the bumper cover off and pulling the whole light assembly off.
    Oh, well, only took about 30 minutes.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    @MaryGeorge, Are you actually being serious or are you messing with us? A model 9003 halogen headlight bulb is about $14 at AutoZone, or ~$22 for a 2 pack. They can be replaced in 10 minutes.
    Did they install a complete headlight assembly for that price or just bulbs?
  11. JC91006
    16,933
    8,643
    The repair manual actually calls for the removal of the bumper, a dealer would charge $150. People with small hands and have done it before, can usually do it in 10 minutes or less
  12. Stevewoods
    664
    1,252
    where I am
    Dudes, the dealer charges anything from about $200-$300 to do this "bulb change."
    As noted, Toyota says the bumper has to be removed to do the bulb change. In many cases, it does not. I did it in about 10 minutes some 18 months ago without removing the bumper. However, earlier today, unable to do UNTIL I removed the half the bumper cover.
    Still only took 30 minutes. Bulb was $8.95 at a local discount store (Bi-Mart). Phillips 9003.
  13. MaryGeorge
    Seattle
    I’m totally serious. It was $150, took them a short time, and it was just the bulbs.
    Years ago I replaced the whole headlight in my ‘92 Toyota 4x4 extended cab. The only way to do that one was to take off the bumper. Nowadays (don’t laugh too hard) I don’t bother doing the work myself because I don’t want to break a nail
  14. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Anyone in the Columbia, SC area...if you need new bulbs installed, hit me up..I can offer a heck of a deal :D
    Skibob likes this.
