2008 Hybrid Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Iamjo20, Dec 27, 2015.
  1. Iamjo20
    Iamjo20 Member
    259
    Are these batteries warranted for 10 years or 100,000? Any experiential data regarding the life span of the 2008 hybrid batteries?
    Thanks!
    JO
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Depending on where you live it's either 8 years or 100000 miles or 10 years or 150000 miles (Carb states have the longer warranty).
  3. Iamjo20
    Iamjo20 Member
    259
    I am in Florida--thought it was 10 years --thanks!
    52,848
    nope. 8/100 in florida, but you get other bennies from the mostly conservative government.
    you would probably need an emissions inspection to become a carb 10/150 state.
    my daughters '08 is still getting the same 55 mpg average at 100,000 miles as i got when i picked it up new.
  5. Iamjo20
    Iamjo20 Member
    259
    Thanks!
  6. bisco
    52,848
    not many reported here as failing, i know that much. it's been '05's and sixes, and just creeping into the 7's.
  7. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Have a 2007 with 164K miles and it is running just fine.
    dbcassidy and Iamjo20 like this.
  8. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
  9. Iamjo20
    Iamjo20 Member
    259
    wow---I must be driving too many short trips--I get an average of 48 MPG..... I have to really get some preventative maintenance done--but only want to choose those items required--low mileage vehicle--26,000---- BUT I also have a patient itch for a new vehicle---
    ty!
  10. Iamjo20
    Iamjo20 Member
    259
    that is great! :)
  11. bisco
    52,848
    you don't need much at 26,000, but that is telling about your driving habits. you might be better off with a bev or econo gasser.
  12. jpr0930
    jpr0930 New Member
    Wake Forest, NC
    I have a 2007 with 86K miles and the HV battery failed a week and a half ago. :(
  13. bisco
    52,848
    warranty?
  14. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    We do not have real good data on battery life, but there are quite a few threads in the past. We did some surveys.
    Consumer Reports did a survey a couple years ago suggesting 3-5% failure rate at the 8-10-yrs old mark. As mentioned by Bisco, anecdotally those failures seems to start approx. at the 8-yrs old mark
    On PriusChat, where we have a very small sample set in our surveys, and we always measure higher battery failure rates here (up to 20-25% or so at the 10-yrs old mark). Presumably the reason is sample bias on PriusChat due to people logging in due to battery issues.
    In any case, I always feel battery life is a valid topic to discuss on PriusChat, since many of our readers are here to discuss that.
    Factors leading to HV battery failure are hotter climates, and on Gen2, running out of gasoline and then running down the battery to zero.
    #14 wjtracy, Dec 30, 2015
  15. Iamjo20
    Iamjo20 Member
    259
    ???????---Jo
  16. Iamjo20
    Iamjo20 Member
    259
    thanks!
  17. Iamjo20
    Iamjo20 Member
    259
  18. bisco
    52,848
    you said you were itching for a new ride? an electric car, or 30-35 mpg gasoline might be more suitable for your short trips.
  19. Iamjo20
    Iamjo20 Member
    259
    LOL--gotcha---wanted to see the new Prius---and I am NOT totally sure which electric ride to trust.....I am attached to the prius branding, and know their hybrid system has been one oft he best; I have ridden in a Ford Eco--that was not too bad---just want to plop my money on something good! And MORE sound proof---
  20. bisco
    52,848
    if you hadn't mentioned more soundproof, i would have said a used pip might work.:cool:
