2008 inverter coolant pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ninajanell, May 9, 2017.
  1. Ninajanell
    Ninajanell New Member
    Manhattan Montana
    I'm new to this but I just bought my 2008 prius with 122000 miles on it and about a week of having it the warning light and check engine light came on. Drive to the nearest AutoZone ( 20 miles away) the car was driving fine the whole way there and back. Code was for inverter coolant pump performance. The lights turned off the next day. Happened again a week later but lights turned off a few hours later. Happened not even a week later again took it into the Toyota dealer in town no codes popped up except for fuel run out. They erased the code but lights turned back on again 2 hours later. Then a couple days later the lights turned on and then off the next day. The lights just turned on, car drives perfect, a.c. works amazing! Anyone know if it's bad wiring or fuse? I know nothing about the prius.
  2. JC91006
    16,939
    8,647
    Your inverter pump has failed. Next time the warning light comes on, check if the ac still works. When the failure occurs, it often disables the ac cooling.
    Also check your oil level as the car will use oil. Add as needed
    SM-N900P ?
  3. Ninajanell
    Manhattan Montana
    The a.c. is working and has been working the whole time. Oil is full and has not needed to be topped off. Toyota said that the fuel run out light could trigger the other lights on. The car is running perfect just lights keep coming on.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    An easy test is to look for turbulence in the coolant in the plastic reservoir attached to the inverter (large silver cover on driver's side under hood). Put the car in IG-ON mode (push power button twice, foot off brake), take cover off reservoir, shine flashlight in, you should see the pink fluid moving slightly. You should also be able to hear an aquarium pump-like sound from just behind the left headlight.
    M in KC likes this.
  5. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Other than what has already been suggested you could verify the electrical connector to the pump is securely attached and not compromised from the PO.
    If it is your inverter pump, and fwiw I tend to agree with the previous diagnosis, its an pretty easy R&R. I just did mine as a preventative measure when I changed my inverter coolant two weeks ago. These are common failure part on this generation Pri. And if you don't have the service history of when the inverter coolant was lasted changed I'd encourage you to add that to your service list at the next opportunity.
  6. Ninajanell
    Manhattan Montana
    If it was the coolant pump wouldn't my a.c. stop working. It's working just fine and the car isn't running weird. I guess I'm just confused on how to know if it's my pump or not
  7. JC91006
    16,939
    8,647
    The pump cools the car's inverter. When you drive the car, it heats up and the AC will stop working and warning lights come on. When the car is off, it'll cool and things might go back to normal, the AC will work again and the warning lights will go off. This repeats itself whenever the car overheats.
    As you've stated, it happens after you drive for a while. It doesn't start right when you first get in your car.
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Check the pump just like andrewclaus has outlined above, either by looking in the reservoir for fluid turbulence OR try finding the pump and touch the plastic housing to check for vibration (assuming you can't already hear it), neither is fool proof and if the pump has never been changed before now could be a good time.
    Which state was the vehicle originally purchased in and is the vehicle under warranty?
    You should contact the dealer (over the phone or in person) and inquire about outstanding recalls that you may qualify for, some might even be related to your issue: http://media.fixed-ops.com/Toy_Campaigns/c0u-dlr.pdf
    You can always check dealer service records with your VIN if you are unsure about previous dealer related repairs having been performed or not.
  9. Ninajanell
    Manhattan Montana
    The car was originally purchased in Arizona. Only one previous owner and the pump was replaced when the recall was released. I have Toyota doing a full diagnostics on the vehicle Saturday. But would rather save the money and fix myself. Is it a easy fix or do I need a mechanic to fix it?
  10. JC91006
    16,939
    8,647
    The pumps usually go for about 100k miles and they can start developing issues. Check the mileage since the recall.
    You are still not certain it's the pump, so if you decide to replace it, make sure it has about 100k miles on it. Just in case it's something else, you can treat this as preventive maintenance for the pump
    SM-N900P ?
  11. Patrick Wong
    18,214
    6,531
    Well, "easy" or "hard" depends upon your level of wrenching skills. Maybe my post here will help you decide whether you can DIY or not.
    How to Replace the Inverter Coolant Pump | PriusChat
    SFO likes this.
