2008 Malfunction and trouble codes
Discussion in 'Gen 2 Prius Technical Discussion' started by LC39B, Dec 13, 2012.
  1. LC39B
    LC39B Junior Member
    Central florida
    Britprius, I did not take it as a scolding, I actually appreciate the help and may be a little sensitive because I cant do a lot right now. I do wonder why Oil change intervals would be diferrent between Britain and the US, curious. Jeff, thanks for the heads up on the 50k change, I guess it is obvious that I did not look in the manual. I am going to pull it from the glove box and go through it as a refresher. You guys do anything special at tuneup time? any special plug wires or just OEM replacements and a type plug better than another? I picked up Bosch before my surgery and have not put in yet. Thanks agiain guys for the input.
  2. Norie
    Norie New Member
    Well, since I picked up my Prius, it's been up and running again...no sign of bad battery. But the heater/air conditioner gets stuck; no air blowing. This problem started just this past summer. I thought replacing the water pump would solve the problem, because it seems the system is overheating. But it's still doing it and around the monitor gets hot. Is it simply A/C unit is going bad? Does anyone have this problem?
  3. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    This is usually a problem with the brushes (stuck or worn) in the heater fan motor.
    You can check this out by removing the cabin air filter and if you look down through the slot with the fan turned on low you should see it rotating. If it is not try spinning it with you fingers, as this usually starts it running.
    It is easy to remove from below and can either be serviced by you or an aftermarket motor is available cheaply.
  4. Britprius
    5,194
    1,924
    I have used Bosch plugs in the UK on other vehicles without problems, but the consensus of opinion hear on PC is not to use Bosch because of quality problems.
    Maybe the US and UK/EU plugs are made in different places, but Bosch parts are normally of high quality this side of the pond.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    They are high quality here as well. I fear some people on this side of the pond are biased.
    Britprius likes this.
  6. Norie
    Norie New Member
    O.K. I'll try to do it by myself. Thank you so much!
  7. Britprius
    5,194
    1,924
    Let us know what you find and ask if you strike problems.
  8. Britprius
    5,194
    1,924
    I live on this side of the pond you live on that side of the pond.
    usnavystgc likes this.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Ok, I got you. Lol
  10. Norie
    Norie New Member
    I went to oil change yesterday, and the dealer tech check-marked the drive belt was cracked. So I asked the service writer about it, and he said as a car gets old, the belt get old and needs to replace. I just had the water pump replaced about a month ago. If it's the case, they didn't replace the belt, I i magine... Or are we talking about a different belt?
  11. Britprius
    5,194
    1,924
    There is no different belt. There is only one drive belt on the gen2 Prius and it drives the engine water pump (coolant pump). It drives nothing else as the Prius does not have an alternator, and the AC is electrically driven, as is the power steering, it seems this dealer is trying to have two bites of the same cherry.
    I would go back and ask that they change the belt for just material cost (still expensive) as this should have been replaced at the same time as the pump. The dealership can have no reasonable excuse for this.
    John (Britprius)
  12. Patrick Wong
    18,214
    6,530
    Norie, the 2G North American Prius has four coolant pumps:
    The pump powered by the serpentine belt is the engine coolant pump.
    The pump covered by the recent recall is the inverter/transaxle coolant pump.
    In addition, there is a coolant heat recovery system pump, and a heater core pump.
    If the "water pump" that you posted about is the inverter/transaxle coolant pump, then the repair tech would not have had any reason to do anything with the serpentine belt.
  13. Britprius
    5,194
    1,924
    Good point Patrick.
  14. Norie
    Norie New Member
    O.K. Thanks for all the inputs. Next thing is the oil weight they use for Prius. The owners manual & oil cap say 5W30. But my local dealer put 5W20. So I questioned them. Then they said it's o.k. to use 5W20 on all Toyota vihicles because we are in south region. Does anybody agree w/that?
  15. Patrick Wong
    18,214
    6,530
    What does "south region" mean? Can you be more specific?
  16. Britprius
    5,194
    1,924
    Many on here use 0w20 oil as I do myself. I was not aware that there is such an oil as 5w20 but could be wrong. It would be advisable to keep a check on the oil level on a regular basis "if you do not already" just in case your engine uses more of the lighter viscosity oil.
    John (Britprius)
  17. bobodaclown
    bobodaclown Member
    216
    72
    That doesn't necessary make sense to me. I think 5/30 would be more appropriate for warm areas 5/20 for cooler areas, but looking in the maintenance manual it doesn't specify 5W20 at all.
    It states that 5/30 is recommended, if it's not available use 10/30 but use 5/30 on next change.
    http://www.toyota.com/t3Portal/document/om/OM47614U/pdf/sec_04_03.pdf
    I'd ask for the copy of the TSP or Service advisory to use 5/20 vice the 5/30 to keep with the paperwork.
    Also this is from the Service Manual (1NZ-FXE LUBRICATION – LUBRICATION SYSTEM):
    2. CHECK ENGINE OIL QUALITY
    (a) Check the oil for deterioration, water intrusion,
    discoloring or thinning.
    If the oil quality is visibly poor, replace the oil.
    Oil grade:
    Use API grade SL "Energy-Conserving", or
    ILSAC multi grade engine oil.
    SAE 5W-30 is the best choice for good fuel
    economy and good starting in cold weather.
    If SAE 5W-30 is not available, SAE 10W-30 may
    be used.
    However, it should be replaced with SAE 5W-
    30 at the next oil replacement.
    That being said you're ahead of the game if your changing your oil regularly and the difference between 5/20 and 5/30 isn't major.
    Motor oil - Wikipedia, the free encyclopedia
    http://www.api.org/certifications/engineoil/categories/upload/motor_oil_guide_2010_120210.pdf
  18. Norie
    Norie New Member
    I'm not sure what " south region" means, but I'm in Florida. The local b/s dealer is Bob Tyler in Pensacola, Fl.; quoted it's o.k. to use 5W20 in all Toyotas! Yes, I read the owner's manual, and it didn't state anything about 5W20 though it mensioned to use 10W30 if 5W30 is not available. I asked them for a copy of written permission to use 5W20 on all Toyotas, because I was going to send it to Toyota Headquarter, but of course they don't have it. On top of that, if I want to use 5W30 on my Prius, they have to use bottled oil, not bulk, so I have to pay more, and they refused to put 5W30!! Well, I reported to Toyota Customer Relations yesterday. Today I spoke to the service manager of Bob Tyler, and they finally changed to 5W30 w/no charge.
  19. Patrick Wong
    18,214
    6,530
    I agree with your comment. Usually you would expect to use a heavier viscosity in a warmer area, not the reverse.
    Well, that is not correct. For example, the current Prius (2010+ model years) needs 0W20.
    I'm glad that you got 5W30 after all (as long as they didn't just park your car in the service parking lot, have you wait a couple of hours, then tell you that the oil was exchanged without actually doing anything...)
  20. Norie
    Norie New Member
    Oh, I know what you mean, so I digged... I asked the service writer how I would know they're gonna put wright weight this time, if they do change. He was upset, but the service manager came and said they'll show me when they put oil, and they did :)
