2008 No start Diag Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hrodgmc, May 30, 2020.
  1. hrodgmc
    hrodgmc Junior Member
    georgia usa
    2008 Prius 1/08 Build
    It’s been sitting for 6-8 months.
    Replaced traction battery
    No start condition
    Red Triangle of Death
    New AGM battery 12.2 volts
    Codes:
    P3000
    P0AFA
    C1241
    C1259
    C1300
    C1310
    B1400
    B1442
    Where do I start with diag?
    Thanks
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    When did you replace the HV battery?
    What did you replace the HV battery with, was it new OEM or something else?
    Raytheeagle and hrodgmc like this.
  3. hrodgmc
    georgia usa
    Hv hasn't been replaced.
    Is that step #1?
    moto g(6) ?
    52,763
    your third line says 'replaced traction battery'
    how many miles on her?
    edthefox5 likes this.
  5. bisco
    52,763
    12.2 volts is almost dead. put a charger on it.
    hrodgmc likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Then @SFO asked:
    Then @hrodgmc replied:
    Is that step #1?
    And I now state....
    I'm so confused, lol, but we're here to help. There's enough member knowledge here that we'll get you fixed up.
    It's just a matter of getting terminology organized.
    I'll go with the assumption the 12v battery was replaced. The first thing to do is ensure the 12v battery is fully charged to prevent you from chasing your tail during troubleshooting. There's always the chance this may cure other issues also.
    Most likely, after sitting 8 months, you have one or more modules in the HV battery that have self-discharged and are causing problems.
    Where are you in Georgia?
    hrodgmc likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    P3000 is replace the hybrid battery. The 12 volt battery is probably bad too.
    Before you reply do some reading please. Use the search forums tab up top and search
    hybrid battery
    and see what everyone and there brother is going through with there G2 and the hybrid battery.
    hrodgmc likes this.
  8. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    P0A80=Replace Hybrid Battery Pack
    P3000=HV Battery Malfunction. Triggered by the Hybrid Control ecu receiving an abnormal signal from the HV Battery ecu. I think there are 5 subcodes to help isolate the actual cause. Anything from fuse blowing, fan failing, battery ecu failing, abnormal low voltage, etc.
    And you are 100% correct about Prius chaos going on now that so many have sat idle for 2 months during lockdown. Anyone with a Gen 2 and an original battery is likely to be in the hurt locker. Not to mention how many dead 12v batteries.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    as far as hes concerned he needs a new hybrid battery.
    #9 edthefox5, Jun 1, 2020
  10. hrodgmc
    georgia usa
    HV battery is original. This car was purchased non running with mininal details.
    We installed a new 12v battery and put a fully charged snap-on jump box during startup.
    190k miles on the car. Unknown history. I will be looking at battery pack today and verifying ready light is off or on. Will report
    Where are you in Georgia?[/QUOTE]
    Vidalia GA almost between Savannah and Macon
  11. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Without a charged and functioning HV battery you will not be able to start the engine, as that battery also rotates the engine.
    Raytheeagle and edthefox5 like this.
