1. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    2008 with 240k miles.
    We're 2nd owners since 95k.
    It was my car and is now my daughter's, she was driving and got the RToD "problem" warning on the display screen, red car with exclamation on display screen, and a few other lights.
    She called me as soon as it happened while she was driving and I had her tell me what the HV battery bars looked like on the display. She said it was green and then dropped one bar while we talked and she got the car home.
    I ran the code later on and got the P0A80 code on torque lite. I then went out with the Dr. Prius app and took a look, but I don't really know what I'm looking for or if these read outs will even tell me anything other than the 1 obvious cell that has issues.
    I took several screen shots, the first one is with the battery down to 2 or 3 bars because I had just been out with the dome light on fiddling with the torque lite app earlier. The ICE was not on when I took any of the screen shots.
    Then I started it up and drove a few miles. It didn't take long for the battery to go up to all green and then alternate between that and 1 missing bar.
    The other 3 screen shots are from sitting with the ICE off after returning from driving those few miles.
    Screenshot_20210911-223622_Dr%20Prius.jpg Screenshot_20210911-223632_Dr%20Prius.jpg Screenshot_20210911-223635_Dr%20Prius.jpg
    Does any of this info actually tell me anything? Thanks
    SM-G981V ?
  2. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Your highest and lowest blocks (1 and 10) are causing you problems. I wouldn't be surprised to find that a module in block 1 had been replaced at some time with a stronger (when compared to the other 12 blocks) one.
    If you can source some modules that match those other modules (i. e. excluding one or two modules in each of blocks 1 and 10) then that battery will run a lot better. You would then need to identify the too strong/too weak modules and replace them with modules that better match the remaining modules.
    If all that is too hard, you'll be looking at the replacement of all modules with brand new ones to give the most reliable fix for your daughter. Any other repair using secondhand modules/batteries will just be too unreliable unless your idea of fun is tearing down the battery every six months at the most inopportune an inconvenient time.
  3. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Thanks for your reply. I haven't torn into it yet as I'm still trying to decide if I have any desire to start this process.
    I really doubt anything has been replaced in this pack as we've owned it since 95k and I can't imagine there could have been anything done to the pack before 100k but I suppose anything is possible.
    My options as I see it are to individually test all 28modules for load and capacity using equipment yet to be purchased and replace those modules that have not recovered enough capacity. This seems to be days and days if not 2 weeks of work to be able to cycle the modules 3-5x only 4 at a time using a hobby charger-discharger.
    Or
    Get the prolong deluxe system and perform the charge discharge cycles up front, then replace likely block 10 modules as well as any others that seem to have not responded well to the cycling.
    Method one is cheaper financially but very expensive in time.
    Option 2 is more expensive financially but waaaaay cheaper in time spent baby sitting...and I'll have the system to use on my gen 3 prius with only a harness purchase.
    Decisions, decisions...
    SM-G981V ?
  4. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    These are a couple screen shots after having cleared the codes once the car had gone into what seemed like limp mode.
    The first 2 while discharging, 3rd while slight charging, 4th while heavily charging.
    I don't know if these show anything else worth noting but I am preparing myself for a looooong drawn out saga if we keep this car.
    Screenshot_20210914-205918_Dr%20Prius.jpg Screenshot_20210914-205843_Dr%20Prius.jpg Screenshot_20210914-210011_Dr%20Prius.jpg Screenshot_20210914-205907_Dr%20Prius.jpg
    SM-G981V ?
  5. bisco
    52,776
    i would just get a new battery and be done with it
  6. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Yeah, I'm just trying to avoid putting as much money into it as what it's worth...especially with 240k on it and using 1.5+quarts between oil changes.
    If I can spend less than $1k and get it to last another 30-40k I'd be thrilled. Spending $2-2.5k and have it last only another 30-40k I would not be so happy
    SM-G981V ?
  7. bisco
    52,776
    $1,600. if you install, but i see where you're coming from. it just sounds like a whole lot of time and aggravation
  8. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    I had just been reading some threads about that replacement module kit. I'm definitely not ruling that out.
    However, the prolong deluxe as a way to attempt balancing the system after replacing known problem modules has other benefits as I have a gen 3 that could use the prolong for extending its life as well as a buddy of mine that has both a gen2 and 3 that could use prolong. If we split the cost of prolong and buy our additional harnesses we may be better off in the long run...I don't know. 4 vehicles getting HV Batt maintenance seems worth it but maybe not. I'm in uncharted territory here.
    SM-G981V ?
  9. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Ok so last night I finally decided to pull the pack from my '08 and see what's up.
    It had been sitting for nearly 2 weeks so it was certainly not freshly charged straight from a running vehicle.
    I checked the block 10 modules right away just to see what the starting voltage was and saw #19 was at 6.60v...and there it is. The rest are at least normal.
    I hooked up a motorcycle headlamp and did a 1min load test on each(85watts). Probably should have done 2min or maybe more but I was anxious to at least get some data started.
    If I take out the #19 values the avg after the 1min load was 7.48v
    My worst 4(besides 19) were:
    7.37v
    7.38v
    7.39v
    7.40v
    Is that far enough below the avg to be concerning after only a 1min load?
    ...Or is the voltage drop under load the more important number? Avg delta V is .47v(without 19) and I have 5 modules more than .05v than the avg. Only 1 of those 5 with the larger delta Vs is also one of the 4 above that had the lowest 4 voltages after the load.
    I will probably do a 2min load tonight after bringing home some gator clips to make life easier...should I go longer on the load?
    SM-G981V ?
    #9 Dilbone, Oct 5, 2021
  10. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Here's a 2minute load test with the 80/85watt motorcycle headlamp with both high and low powered.
    Avg voltage drop from original voltage measured is 1.02v
    Only 3 or 4 modules varied much, but even those were within 10% of the avg.
    Is being within 10% of the avg acceptable?
    The more I look at this data it just seems like #19 is really the only issue.
    SM-G981V ?
  11. dolj
    dolj Senior Member
    8,633
    4,387
    I'd agree with that. Find a new module that drops by 1 (ish) volt from a similar starting voltage and you will be good to go.
    Remember module #19's issue is that the open circuit voltage has a difference of 1.2 V or more when compared to the other modules in the pack - indicating a dead cell within that module.
    If you have access to a grid charger, you could additionally do a top balance charge, but you could leave that until later if further battery issues arise down the track.
  12. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Thanks for the confirmation. I was expecting at least a few modules to start to fall off and separate from the average significantly, and maybe the other 1.11v drop is actually significant, but it seems like staying within 10% of the avg drop is hardly falling off a cliff.
    Now I have to decide if buying the prolong basic reconditioning package for just under $500 would be enough to keep this car going another 60k miles or if I should just place the bandaid of 1 "new" module on it and let it ride as is until I can get a newpriusbatteries kit when we start having issues with the pack again. I just don't want to do the prolong thing, then end up in 10-20k still needing to do a whole new pack anyway.
    I'm leaning toward letting it ride as is since it's clear I have not just a weak module but one with a cell out...oh well, it's only money right?
  13. dolj
    dolj Senior Member
    8,633
    4,387
    I wouldn't spend on a HA prolong kit If your medium-term plan is to get a newpriusbatteries kit in any case.
    The Prolong system is really to buy time, but the ultimate fix is to replace the battery with new modules then you won't be thinking about the battery again for the next (at least) ten years.
  14. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    The real question is how much time the prolong will buy me??? And of course no one knows the answer to that.
    I don't need 10yrs...and won't try to get 10 more yrs out of this 242k 2008 prius....which makes me hesitant to make the investment in a new battery...
    I can't even get newpriusbatteries to respond to my question about how soon one would be available to purchase...so that may not be an option anyway right now.
    I guess I'll let it ride as it is with a replacement module and see how long that lasts me.
    SM-G981V ?
  15. dolj
    dolj Senior Member
    8,633
    4,387
    Correct.
    You are sending mixed messages. If the above is your true position, change the bad module for a closely matched one, then invest in a charger and discharger and use it to eke out what life remains in your battery modules. How effective this strategy will be will depend on how close to end-of-life your current set of modules are. There are no guarantees.
    That is because the November shipment has sold out and supply chains are severely hampered by the current COVID environment at present. Even though the company goes into hibernation mode when they have no stock to sell, they do usually eventually reply to emails. However, don't expect an answer to a question where you can find an answer on the website as these emails get pushed to the bottom of the pile. You might not think much of the business model, but it is what it is.
  16. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Yes, mixed messages are due to not knowing what I should do... I need this car to last another 3-4 years. Not long enough to justify a new battery in my mind, but probably longer than the prolong system will keep it going...I'm stuck in no man's land.
    I apparently never saw the "store" tab on the site and just now looked and saw the "next arrival" of inventory date. I don't have any problem with their business model...I just didn't see the information I was wanting on the site. My bad.
  17. bisco
    52,776
    honestly, it is a very difficult position to be in. there really isn't a 3-4 year fix, just a lot of fixing as necessary.
    it's probably too late for prolong, maybe look around for a salvage or rebuilt on the cheap and hope for the best
  18. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    Yeah, that's what I was afraid of. I was thinking if I had a hobby charger I could at least do a top end charge and put them back in the car balanced up and topped off, but I'm not even sure that would matter at this point. Maybe I just buy the new battery, install by the new year, just keep adding oil, and push this SOB to 500k miles!!!!!!! Hahahahaha
  19. bisco
    52,776
    if you're willing to do the hobby charger on individual modules, it's the most reliable way to go. but it is a ton of work and downtime, with a uge learning curve.
  20. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    I got the new module in yesterday from 2nd life battery.
    It tested at 8.05v out of the package.
    I then did a 1min load test followed by a 2min load test dropping it to 7.37v and 7.14v respectively with a 10ish min break in-between.
    Definitely a bit stronger on the 2min than the rest of the modules in the pack.
    I reassembled the pack replacing #19 with the "new" one. Then I reverse installed the rest starting with #1 in the #18 spot and ending with #18 in the old #1 location. Maybe I shouldn't have done that but I have seen several people mention switching the middle modules with the outside ones.
    I got the pack installed in the car and took it for a test drive. The pack had 1 or 2 bars on the energy display and was showing 37ish% on the Dr. Prius app. I drove it long enough to get the charge % into the 65-68% range and the energy display was staying in the green pretty much all the time. My Dr. Prius app bar graphs are showing the block 10 numbers at about .1v more than the rest...makes me think I should have done another load test to bring the new module all the way down closer to where the other modules were...I had considered it at the time but was just anxious to get the pack assembled and installed. The rest of the blocks are literally within a few hundredths of each other.
    The IR is 1mOhm lower on the block with the new module but the voltage difference has dropped significantly both charging and discharging compared what the old block 10 values were. Less than .2v vs as much as 1.6v with the old #19 in place.
    I might take the cover off in the car and drain the new module a little more to get it closer to the others...not sure if that will matter or if it's the capacity of that module that is so much higher than the rest causing the issue.
    Thoughts on any of that? Screenshot_20211012-214013_Dr%20Prius.jpg Screenshot_20211012-214035_Dr%20Prius.jpg
    SM-G981V ?
    #20 Dilbone, Oct 13, 2021
