For Sale 2008 Prius 28 Modules 50k mi & Gen 3 case w/components
Discussion in 'Private Sales' started by freshedie92, Oct 21, 2015.
  1. freshedie92
    freshedie92 Member
    73
    37
    San Bernardino, California
    Hello :)
    History:
    I replaced my battery on my 06, these cells are leftover from my extra battery i bought. They are all matching serial no., I have some data using techstream from when the cells were in my prius I will eventually add that to the post. I tried charging and discharging 2x with my grid charger, but I gave up and ended up using my original battery as it had better results. This one has just been sitting since February.
    How it performed:
    There is no swelling or cracking that I can see. While the battery was in my car it actually was able to drive decently (47 mpg actual), but if I tried to keep it in electric mode for extended periods with gas pedal it would cause the car to go quickly between power and no power causing a jerking motion.
    I firmly believe this set would be prime candidate for rebalancing, but I have no need for cells and no balancer, and not a lot of time.
    08 modules 50k mi----$250 firm for the set. (less than $10 each)
    Would really rather sell locally in so cal
    I also have the gen 3 case and components includes ecu and cables, but i did use the copper contacts on my battery swap. -$150
    located in San Bernardino Ca
    Thanks for looking,
    #1 freshedie92, Oct 21, 2015
  2. JC91006
    16,936
    8,647
    PM sent, I'm interested
  3. freshedie92
    freshedie92 Member
    73
    37
    Sale fell through if anyone is still interested.
    #3 freshedie92, Oct 21, 2015
