2008 Prius A/C noise
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Apr 17, 2021.
  1. richard203
    richard203 Member
    283
    61
    SF
    52,857
    sounds like a damper
  3. richard203
    richard203 Member
    283
    61
    SF
    whats that i tired googling it doesnt show much
    52,857
    the hvac system is comprised of motorized vent doors to direct airflow. there may be an automatic change when you press a/c, idk. try pushing the vent direction control button and in/out air button to see if there is a similar noise anywhere.
  5. richard203
    richard203 Member
    283
    61
    SF
    ok, i'll try today and report back.
  6. richard203
    richard203 Member
    283
    61
    SF
    yep i tested when i do outside air and turn bak to recirc it makes noise and when i turn recirc to outside air it makes noise. so its the motorized vent door? and where do it located?
  7. bisco
    52,857
    i've never dealt with it. there are a few buried in behind the dash, but iirc, one is availabl to spray lube from the floor vents.
    the fresh air/recirc may be behind the glove box in the cabin filter area.
    do some searching, there have been diagrams posted over the years and repair proceedures.
    in the end, some just put up with it unless it stops working.
  8. bisco
    52,857
