2008 Prius ABS Control Module Failure - Questions w/ Diagnostic Screenshots
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Geedis, Jun 17, 2019.
Tags:
  1. Patrick Wong
    18,210
    6,517
    Hmm, I do not think that any programming is required relative to replacement of the brake actuator. Check eBay regarding establishing a reference cost of a used unit.
  2. ChapmanF
    19,008
    Does it have an offset-learning step like the gen 3? Maybe that's what somebody would call programming.
  3. BLNT
    BLNT Junior Member
    37
    Hungary
    The 'programming' part might relate to bleeding the system that can be done as far as I know with the Toyota Techstream (TS) Diagnostics system. Maybe the mechanic has the system (It can be even bought from Amazon). Overhere in Hungary, this service set me back a few hundred $. This price in the US might be reasonable as I saw a few posts in the Facebook group. It is a big job though.
  4. Tokar
    Tokar New Member
    Land Of Ta
    Are you the true Geedis from the Land of Ta?
  5. Patrick Wong
    18,210
    6,517
    True, it is necessary to initialize the linear solenoid valve and calibration.
