2008 Prius Clicks Once When Accelerating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grogboshi, Jan 7, 2017.
  1. Grogboshi
    Grogboshi New Member
    Virginia
    Hi all,
    My 2008 Prius with ~154,000 miles clicks once when accelerating. This only happens when the engine kicks in while driving. If I accelerate from a stop using only the electric motor, there is no click. In addition, if I am sitting in park and simply rev up the engine, there is also no click. The click is loudest when accelerating from a stop, but sometimes - though not all the time - there will be a click when accelerating from rolling down the road, and it is quieter then. Other than the single click, I have no trouble accelerating, steering, turning, or with anything else. This has been occurring for a few thousand miles now. I believe the click is also louder when it's especially cold outside, or if I haven't started up the engine and driven in some time.
    I appreciate any insight you all can provide.
    52,855
    welcome! any idea where the click is coming from? is it loud enough to record?
  3. Grogboshi
    Virginia
    It's coming from the front of the car, I imagine either the engine or the suspension. I created a quick video where you can hear the sound. I was on a hill and accelerating up and the click was pretty loud. I turned around the tried to make another video going down the hill and only heard the click once, faintly, out of the three times I tried, so perhaps starting from a stop under the stress of going uphill makes the click worse.
    edthefox5 likes this.
  4. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Have the front control arm bushings checked. When they go you have metal slapping on metal.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Wow a new one. Never heard that before. Sounds like it has something to do with the inverter.
    Is the ac off during this?
    Does it make that noise if your just sittting in the car and not moving and the engine happens to come on?
    Hope so because if it does just open the hood when the engine is off and wait till it starts. Or get someone to floor the accelerator and the engine will start while you listen, while listening under the hood try to locate the sound location.
    Also go on you tube and search
    Prius inspection mode
    That mode enables the engine to run continuously for inspection. Let it run and listen to it. Make sure engine oil is at full line and inverter coolant is bubbling in the tank.
    I recommend everyone put it in inspection mode once and give a good listen to the motor so if anything ever occurs you will know what it's supposed to sound like. The engine has solid lifters so it's pretty clackity clack loud compared to other engines.
  6. Grogboshi
    Virginia
    It does it whether the AC is on or off, and sadly it does not click when just the engine is running. Either when the engine comes on by itself, or if I'm sitting in park and rev the engine or in drive and rev the engine with my foot on the brake. It only clicks when the engine kicks in while moving. I put it in inspection mode and looked over everything and it's all running fine; the engine sounds the same as it's always sounded - which, as you said, is pretty clacky.
  7. JC91006
    16,936
    8,647
    Has this car been in an accident before? That's a very sharp click, can't think it would be from the engine area
  8. Grogboshi
    Virginia
    No accidents. Nothing beyond occasionally scraping the bumper on a speed bump or when turning into an incline.
  9. Patrick Wong
    18,210
    6,517
    I am wondering whether the damper located between the engine and transaxle might have a broken spring or getting loose.
    valde3 likes this.
  10. Grogboshi
    Virginia
    Thanks for the suggestions. I'm taking it in tomorrow, hopefully these will narrow down the possible suspects and we'll get it figured out.
  11. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Is it making the noise if you sit in drive pressing hard on brake with left foot and then press throttle with right foot? Try to stab the throttle to get it to make the noise.
  12. Grogboshi
    Virginia
    It does not happen while stationary, even with the throttle pushed down to the floor.
  13. Josephphamy
    Josephphamy Junior Member
    43
    Long Beach CA
    Did it click if you turn off the AC? Sounds like the AC Air compressor clutch.
  14. valde3
    2,002
    750
    Finland
    In drive? Throttle pushed down in park doesn’t actually run the engine (it’s just spinning with MG1).
  15. Chris Jay
    Chris Jay New Member
    York PA
    Does it sound like this:
    I am having a similar issue and got a check engine light sometimes with a catalytic converter code so I am thinking that is what it is for me. Did you ever figure out what it was for you?
