2008 Prius clock doesn't keep time
Discussion in 'Gen 3 Prius Audio and Electronics' started by Garry, Nov 19, 2014.
  1. Garry
    Garry New Member
    The battery has not been disconnected. Any answers?
  2. JC91006
    16,936
    8,647
    The battery is dying or you have a loose connection
  3. Garry
    Garry New Member
    Thanks. It's only 3 years old but a few times I haven't been able to start the car. I should have figured it was the battery but it's no that old.
  4. JC91006
    16,936
    8,647
    These little batteries typically lasts around 4 to 5 years. But once it has been drained, the life span will be reduced. It's time to change the battery before you get stranded.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Well then it could be a bad connection at any of the 4 connection points for the 2 main battery cables.
    Problems at the body-frame connection for the negative cable seem to be fairly common.
    Anyhow, all 4 connection points need to be removed, cleaned and re-attached and the battery needs to be tested.
    While a "good" battery test sometimes isn't conclusive, a "bad" test almost always IS.
