2008 Prius Code Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zrman, Nov 14, 2022.
  1. Zrman
    Zrman Junior Member
    Michigan
    Code # Status Message
    B1421 Current Solar Sensor circuit (passenger side)
    of rearspeed sensor rh
    C1278 Current Abnormal change in output signal of rear speed sensor lh
    C1281 Current Master cylinder pressure sensor output singnal is faulty
    C1343 Current Hydraulic System (rr)
    C1346 Current Stroke sensor zero point learning
    sensor lh
    C1275 Current Abnormal change in output signal of front speed sensor rh
    C1276 Current Abnormal change in output signal of front speed sensor lh
    C1277 Current Abnormal change in output signal of rear speed sensor rh
    C1278 Current
    C1272 Current Low output signal of front speed sensor lh
    C1273 Current Low output signal of rear speed sensor rh
    C1274 Current Low output signal of rear speed sensor lh
    P0A93 Current Inverter cooling system performance
    P1121 Current Throttle/pedal position sensor/coolant flow control valve
    position sensor circuit stuck
    P1121 History Throttle/pedal position sensor/coolant flow control valve
  2. JC91006
    16,933
    8,643
    How about a little history of the car and the problem you’re experiencing?
  3. ChapmanF
    18,957
    Don't sweat the B1421; that just means strong sunshine wasn't on the dashboard solar sensor at the time you got the codes.
    You're getting generic fortune cookies from somewhere for non-generic codes; for the P1121 code in a Prius, "coolant flow control valve position sensor circuit stuck" is the correct cookie. It has nothing to do with a throttle or pedal position, except some completely other car uses P1121 to mean that.
    Zrman likes this.
  4. Zrman
    Zrman Junior Member
    Michigan
    the 3 way coolant valve was the first code to pop up, check engine light 2 days after I purchased the car, it turns on for 1/2 day to two days, then no check engine for a couple days. Brake and ABS lights were on when I bought the car. 88k miles Florida car. Red triangle of death cam on 2 times, both times after about 30 minutes in drive on the freeway, 1st time it was gone the next morning, second time went off after a couple stops within about 4 hours. No I was not driving that whole time 3 short drives then stopped at each for about an hour.
    Car runs great, brakes fine, no problems other than irritating lights.
    I’m guessing an inverter pump on the red triangle of death and a connection issue on the sensors. Been looking for a techstream download and cable, just can’t figure out which version will work on my old xp laptop
    which cable too.
  5. Zrman
    Zrman Junior Member
    Michigan
    I bought an OEM valve for the repair, getting smoked headlights, when I do them will do the valve at the same time.
  6. JC91006
    16,933
    8,643
    So basically you have to replace the 3 way coolant valve, the inverter coolant pump, and change the coolant (both loops). Do those simple things and see where it leads you next.
    Zrman likes this.
