2008 Prius Code P0AA6
Discussion in 'Gen 2 Prius Technical Discussion' started by Kevinmatth, Sep 12, 2023.
  1. Kevinmatth
    Kevinmatth Junior Member
    Alabama
    I commented the following posts under a very old thread but decided to make a new thread because of the wonderful outcome that could help someone else out one day.
    Someone please tell me what the B+ 13.73 V is referring to on this detail screen. It's a little hard to see because my laptop screen is going out.
  2. Kevinmatth
    Alabama
    I will also add these other screenshots if anyone would mind giving me their thoughts on it. I found this post because I'm in a similar situation but so far I have not done any of the troubleshooting steps towards these codes I have only run the Techstream and got the codes so far.
    A little history: we purchased this 2008 Toyota Prius in 2015 with 159,000 miles on it and I'm now at 223,000 miles. I haven't had to do anything to it except for routine maintenance oil and fluid changes. I started noticing the ABS assembly actuator having to pump more frequently over the course of time and it finally threw the code and disabled the car. I found a used ABS module for about $100 out of another Prius and I replaced it and it cleared the codes and works great. After I cleared the codes for that there was one code remaining (b1442). I looked into this code briefly and I could hear a creaking noise under the dash and thought that it may be just the damper vent not opening fully kind of like what I read about the b1442. So because there were no lights on on the dash and everything else was running normally AC blowing cold car running great I just left it alone. I also change the cabin air filter and cleaned the HV battery fan which was terrible because it had never been done and it had paper in it and all kinds of dirt I don't know how it was even spinning. After driving the car a couple times over the next two weeks I was backing the car out of the driveway yesterday and it threw the red triangle so I pulled it back up into the driveway and parked it and received these codes and here I am. This car has a lot of sentimental value and I really would like to keep it running so thank you for everyone's help on this forum.
    The strange thing is the current codes no longer show the b1442.
  3. Kevinmatth
    Alabama
    Update: After reading countless threads related to this topic I was devastated believing I had a cell leaking which was creating the electrolytic ground fault bridge. However, I watched a video about how you should check the 12V battery and also the A/C before pulling the hybrid battery. When I got home last night I checked the battery with a multimeter and found the battery very low at 12.3V. I attributed some of the very low state of charge to the fact that the night before I had run the Techstream with the ignition on for the entire health check which took an extended period of time. I purchased this Toyota brand 12v battery on 08/27/20 and it had an 84 month warranty so I figured the battery should be good. I put the charger on it and charged it up, started the car up and the red triangle and vsc light were gone. I drove it around the block several times this morning and was thanking God the whole way. I didn’t even have to clear any codes.
    Next question is 1. What about the b1442 code and should I be concerned about it? and 2. Any other suggestions on how to diagnose the 12v battery parasitic drain other than hooking a multimeter up in series with the battery and monitoring the amp draw with the vehicle at rest?
    The strange thing is I actually checked the 12v battery for parasitic drain after I replaced the ABS actuator. I hooked my super cheap ($9.00) multimeter up in series with the negative terminal on the 12v by way of the following: I drove the car around the block, parked it, opened the front two doors and rear hatch, and tripped the latches on the doors. I disconnected the negative terminal on the 12v, took some jumper cables and hooked the black jumper cable up to the negative post on the battery and the other black jumper up to the black lead that goes to the battery to complete the series. I let the car sit for a little bit then hooked my multimeter up in the series to the two connection points I created with the jumper cables and put the meter in milliamp mode. I was getting next to nothing which was way below 50mA. I was wondering if my meter was working so I pressed the rear hatch button on the trunk and watched the reading jump up in milliamps (I can't remember what the reading was for this) then settle back down. Just because I was already in there I decided to go down the line of fuses checking each one for anything other than 0 millivolts. I could not find any on the fuses that where under the hood. I guess that doesn't mean that there may be an intermittent draw that occurs over a period of time and I just wasn't patient enough?
  4. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Well you're in Alabama hot humid muggy at some point you need to lift up your battery cover for the HV battery and open the front end of the battery and take a look at the orange plug on your HV battery computer If it's showing sign of corrosion and filth you need to take the three 8 mm screws out I think and withdraw the computer take some contact cleaner and clean it up then while you're over there putting it back you may be able to see where the flashlight and see how bad the corrosion is running down the line but that stuff is covered so it's hard to detect just pulling the battery out one weekend and putting new cleaned or nickel bus bars in and new nuts and goes a long way believe it or not and it only takes about an hour or two. So far I've seen it car that was kept on the road that had over 430,000 mi on the original battery because it's being driven doesn't sit that sort of thing I think has a lot to do with stuff.
  5. netsplit
    netsplit Junior Member
    48
    16
    Earth
    +1 opening your battery. Be sure to pull the orange plug on the driver's side to break the high voltage circuit. My wife's car had a P0AA6 code and the issue was one the voltage sensor wires broke right on the ring terminal. Replaced the ring terminal and it cleared the P0AA6 code.
    Even if it isn't, your bus bars that connect the battery cells might have a lot of corrosion and that can caused a lot of issues. Also like Tombukt2 says, check the orange voltage sensor plug on the battery computer. Sometimes they corrode pretty bad. Mine burnt itself to a crisp and had to be replaced.
  6. ChapmanF
    18,958
    Be aware that pulling that orange plug breaks the high voltage circuit under normal circumstances.
    If you have been given the P0AA6 code (INF 612 anyway, or also if it's 526 and you don't yet know it's not 612), you know for certain that normal circumstances do not apply.
    P0AA6 is the code that tells you exactly there is an isolation failure somewhere, in other words, more than one path now in the high voltage circuit, not all interruptible by that orange plug.
    Your high-voltage gloves and other safety precautions are always advisable even in normal circumstances, though many of us here treat them a bit cavalierly.
    Do not treat them cavalierly if you know you have a P0AA6-612.
    netsplit likes this.
  7. Kevinmatth
    Alabama
    In this case it was simply the 12v battery state of charge was too low and all was fixed along with the codes cleared after charging the battery.
    bisco and netsplit like this.
  8. Brian1954
    Brian1954 Senior Member
    2,660
    1,061
    South Central PA, USA
    I predict that the P0AA6 code will return. It is very unlikely that a 12v battery with a 12.3v state of charge will cause this trouble code.
    #8 Brian1954, Sep 17, 2023
    dolj and douglasjre like this.
  9. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    ^^^^^^^^ What they said.
  10. Tombukt2
    13,809
    2,504
    Durham NC
    I'm chasing this now with the same subcodes in the pink at the beginning of this thread and my battery was built by a local battery guy who does this just like green bean and everybody else The battery I removed from the car was in much worse shape He took that battery bought his replacement hooked it up in the car worked immediately He's the one that showed me if the door open light is not on your display is not going to light up so if you're standing at your trunk with the boot open and you looked your dash and you don't see that red light showing the hatches up forget about pushing the start button You're not going to have a display. So I'm thinking his batteries in pretty good shape or it seems to be I will open it up if need be this is also the same guy that told me about the HV battery computers once they start throwing codes get another one and change it especially if the receptacle or the plug have corrosion He believes that HVECUs can just get into a mode where they'll just start throwing codes at the first sign of anything they have voltage monitoring signals going to them 24/7. Then there's this tri delta thing up in the inverter that needs to be checked supposedly I haven't got that deep into this but it's just real strange that replacing the battery cleaned everything up for about 9 hours and then the same code was back with the same subcodes as posted above I guess before I rip open this man's battery I'll probably go and look up near the inverter see about this thing that they're talking about testing is worth doing or just changing out to a known good inverter?.
