2008 Prius Code P1121
Discussion in 'Gen 2 Prius Main Forum' started by yisiling, Jul 26, 2022.
  1. yisiling
    yisiling New Member
    Los Angeles
    Hi! First time poster here. I have a 2008 Toyota Prius with around 111500 miles. The check engine light is on and the code is P1121. Anyone here have an idea how much does it take to get it fixed? I live at LA, can you also recommend a reliable shop for me to take it there? Not a DIYer, that option is out.
    Thanks in advance!
    ydpplqbd likes this.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    That code on a Gen2 Prius (2004-2009) is almost always a failed coolant control valve (aka 3-way valve). This valve directs hot coolant into a thermos tank to speed engine warmup on a cold start. It's helps reduce emissions and has no effect on how the car drives.
    I always recommend using a Toyota part (more reliable). Expect $100-150 for the part, about 2 hours of labor, plus some coolant.
  3. yisiling
    yisiling New Member
    Los Angeles
    Thanks! That's super helpful!!
    52,837
    welcome!
    hybrid pit comes highly recommended
