2008 Prius - Dash Lights Fail Intermittenly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sherryalexis, Sep 19, 2017.
  1. sherryalexis
    sherryalexis New Member
    US
    I just bought a used 2008 Prius Base almost a month ago. The car had several "moderate" problems. I took it back to the dealer several times and they fixed all of the problems.
    However, for some reason, the lights on the dash don't come on sometimes! They've replaced the instrument cluster/combination meter and the 12V batter since the car was in my posession. But the problem persists. I have been using the quick fix of unplugging/resetting the 12V battery but it's starting to be annoying.
    I've noticed that whenever I use my head lights at night, the next morning is when I have this problem. Sometimes the lights come back on on their own and sometimes I use the quick fix.
    When the dash lights go off, the rearview camera doesn't work, the car doesn't beep when doors are open or in reverse, can't see gas, mph, etc. And the screen doesn't measure the mpg while this is happening. The car drives perfectly while in this state by the way.
    Also, the power button LED light is red most of the time. I also have to force power off the car because it won't turn off on it's own. And the horn beeps slightly when pushing the brake hard or holding foot on the brake at red lights.
    Has anyone else experienced this, know what the problem is and how to solve it?
    #1 sherryalexis, Sep 19, 2017
    52,527
    still sounds like a 12v issue, are you up to testing it?
    sherryalexis likes this.
  3. JC91006
    16,872
    8,619
    I think it's because your headlights are on. Try turning them off during daytime, and you won't have this problem.
    Alternatively there's a brightness setting wheel, on the dash, to the left of the steering wheel. If you turn that all the way up, it'll also solve your problem
  4. sherryalexis
    US
    I actually do turn them off during the daytime. Would that cause the power button to be red and rear camera to fail too? All from using headlights?
  5. sherryalexis
    US
    That's what I was thinking but the dealer just replaced the 12V.
  6. bisco
    52,527
    i think the problem is, you're relying on the dealer, and we need feedback.
