2008 Prius dead 12V battery, potential HV battery drain in progress??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josh Lyman, Jan 31, 2021.
  1. Josh Lyman
    Josh Lyman Junior Member
    36
    Washington, D.C.
    My 2008 Prius which has <100k miles had an issue for the last couple days where when I went to turn it on (depress brake, push power button), symbols came up on the dash and the power button was orange (is this accessory mode?). But if I tried to turn the car on again, it would fully turn on with the green LED (ready mode?). It was fine to go to the grocery store, and when I
    My understanding is this is a dying 12V battery and diagnostic mode seemed to confirm that. Today, I planned on getting a new battery, but when I went to turn on the car, it did the orange LED/green LED thing again, except the car wouldn't fully turn on. It got stuck in a loop where I couldn't turn it off and I was afraid the car would end up draining the HV battery into damage.
    I live in an apartment and was able to flag down someone in the parking garage to give me a jump. This had the benefit of finally turning on the main LCD (the MFD?) but it gave an error about the parking brake that I couldn't fix. As far as I could tell, the engine never came on.
    I was able to "turn off" the car, though it beeps when I get in which reminds me of when the car is on but you get out with the key your pocket. I'm fine to walk/Uber to an auto store to get a new 12V battery tomorrow, but my main concern is: is my HV battery getting drained into damage as we speak? Is there anything I can do to ensure the car is fully off until I can get a new 12V battery tomorrow?
  2. JC91006
    16,936
    8,647
    The HV battery does not like to be sitting and not used. If the battery is original from 2008, it may already be weak and out of balance. So it's best you don't let it sit and drive the car weekly. But the issue you are having right now has no relation to the HV BATTERY. It is a bad 12v battery and the sooner you replace it, the sooner you'll be back on the road again.
    SFO likes this.
  3. Josh Lyman
    36
    Washington, D.C.
    I can't speak for the previous owner(s), but I've had the car for a little under 2 years and I drive it on an almost daily basis. Thanks for the head up about the HV battery though, I didn't know that. :)
    If the car is in some weird state right now where it's not truly off, is there a chance the HV is being drained? I ask because I thought the HV battery was used to charge the 12V, but it sounds like I'm wrong? I assume it's okay if the 12V gets drained fully dead right now since I need to replace it anyway.
    I looked up the price of a replacement battery at Advance Auto Parts and it's apparently $220?! Does that sounds right?
  4. JC91006
    16,936
    8,647
    Have you had an occurrence where the dash lights on your car won't turn on? I experienced this issue with a bad combination meter and at times I felt my car didn't shut off. But with a bad 12v battery, it shouldn't have issues shutting down....only starting up.
    But the HV battery does not drain as you described, only battery draining when the car is off is the 12v battery
  5. Josh Lyman
    36
    Washington, D.C.
    The car was always fine until this week when I ran into the problem as described in the OP: I go to turn on the car (brake + power button) and all the dash lights turn on but the power button LED is orange. I "turn on" the car again (brake + power button) and it fully turns on with green LED and the engine starts after a few seconds like normal.
    You say the HV battery doesn't drain when the car is off, but I'm not 100% sure it's off because of the beeping when I open the door.
    #5 Josh Lyman, Jan 31, 2021
  6. JC91006
    16,936
    8,647
    You should be fine, don't worry about the HV battery right now. Just replace the 12v battery and enjoy the car
  7. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Did you do a 12v test?
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Confirm that the mechanic key work in the drivers door. Prop the hatch open with a rag, it can save some effort later on.
    This sounds like a typical failing 12v battery, use a multi-meter to test at the jump points under the hood. Check for standing water in the trunk area, and look for corrosion where the negative strap bolts to the body in the trunk.
    Yes, disconnect the 12v battery.
    How many hours per day/week are you driving?
    Sounds about right, the dealer might be a tad bit less/more and possibly higher quality. What brand does AAP offer?
    If there is a Pepboys nearby, then often have a 25% or $50 promo, usually 150+tax and core out the door.
    This thread may be of interest as well : Fitting mobility 12volt AGM battery. | PriusChat
    Find the dealer maintenance and reported mileage by running the VIN at Track Your Service Records with Your Toyota Owners Account
    Best to research on how to clean up the HV fan, and how to balance the HV battery before something goes south.
  9. Josh Lyman
    36
    Washington, D.C.
    I just checked at the jump points under the hood with a multimeter, I got 8.3V. I've left the car unlocked since it's in an underground parking garage. The red security light still blinks, but there's a beeping when I open the door, maybe to tell me the Smart Key system won't work?
    1) Is my battery salvagable?
    2) If yes, there's a Mr. Tire 3 blocks away. Could I take the battery to them and have them charge it up?
    3) Should I try to find a portable jump/charger from a neighbor in my apartment building to borrow?
    When I tried jumping the car on Sunday, it "turned on" but it gave me an error about the parking brake not being right, so the engine never spun up.
    I have experience accessing the 12V battery area since I installed a cable to power trailer taillights, not on this 2008 Prius but a different one.
    Is this because the hatch is opened electronically and will be a pain in the butt once the battery fully dies? My concern is, wouldn't that light up the dash light saying the trunk is open, further draining the 12V? I may not be able to get a new battery/go to the auto shop until Saturday.
    Since October, my only driving is 10 min (each way) trips to the grocery store and Costco, maybe 3-4 times/week. Sometimes there was a 45 min or so trip thrown in every month.
    These are my options within Uber distance:
    $180 NAPA The Legend Premium AGM Battery BCI No. NA 325 A Glass Mat BAT 9851P | Buy Online - NAPA Auto Parts (napaonline.com)
    $200 Duralast Platinum AGM Battery 340 CCA (autozone.com)
    $220 DieHard Platinum AGM Battery, Group Size S34B20R, 340 CCA S34B20R: Advance Auto Parts
    $220 DieHard Platinum AGM Battery, Group Size S46B24R, 410 CCA S46B24R: Advance Auto Parts
    $284 Optima Yellowtop Prius Deep Cycle Car Battery, Group Size DS46B24R | 513308 | Pep Boys
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    If SKS, then you'll need a 46 Ah model. That Duralast from AZ would be too small at 34 Ah, do they carry the larger version?
    Pick the least expensive battery with the longest "free replacement" warranty, some are up to 4 yr/48 month 'free' warranty
    Most Platinum will have a least 3 yr warranty, some are 4 yr. That NAPA says only 18 months. Would just avoid all Yellowtop batteries.
    Raytheeagle and JC91006 like this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Go with the optima.bring your voltmeter with you to the parts store when they slap it on the counter measure the battery. Should be at least above 12.6 volts.
    Many reports of a really low optima because it was sitting at the store for long time. Anything lower than 12.6 is not good,
    look for store coupon online before going saved me $30.
    after you install the battery first time you boot the car the car all the dash lights com3 on that’s ok it just freaked out cause the 12 volt buss went offline.
    shut it off try again should come on.
    to take the battery out there are 2 cables plugged into the battery assy. Take red plastic cover off hold down there little white click tabs and pull the cables out. Should come right out if they don’t you have not unlocked them.
    unbolt it install it bolt it back up no sparks at all with those 2 cables unplugged.
    take pictures of everything before unbolting it. Everything.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Oh and don’t be surprised to find water in the bottom of that battery well.
    G2s leak.
  13. Josh Lyman
    36
    Washington, D.C.
    After some bloodied knuckles, I was able to remove my 12V battery and it's now charging via a neighbor's 87102C Century 10/2 Amp 6/12 Volt Manual Automotive Battery Charger (centurytool.net)
    Although the charger instructions say to use the 10A mode for car batteries, my battery itself says 4.6A max, so it looks like I'm stuck with the 2A mode and I'll be charging the battery for quite a few hours.
    Two questions:
    1) The battery was down to 4.5V when I started charging. This might be because I left the rear hatch open for about 24 hours (I wanted to make sure I could open it yesterday but I didn't have time to remove the battery). Is there any hope my battery will be usable, or should I just anticipate buying a replacement?
    2) In the process of removing a mounting bolt for the controller that blocks the battery, the bolt snapped in half, apparently from rust. I still have 2 other mounting points--I should be okay there, right? Unless the bolt that snapped is a grounding point. The metal attachment still makes contact with the frame of the car. Maybe I could use some duct tape?
    [​IMG] [​IMG]
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Hey Lemon Lyman listen my bro your wasting your time. Buy a new battery
    Or it will leave you stranded again.
    Once you kill it perfectly and deep (that’s what she said) with a light bulb it will never be the same.
    It will never ever hold a 100% charge.
  15. Josh Lyman
    36
    Washington, D.C.
    I've been charging for an hour and wanted to check on the progress, so I turned off the charger and disconnected the cables. My multimeter is reading 12.4V now. Surely that can't be right??? Also, the charger showed 6A when I unplugged it even though it was on 2A mode and showed 2A when I first started charging.
  16. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Not impossible for a dead 12v to charge right back up, and once loaded down you will notice a voltage droop.
    Can't quite read the date code on that 12v battery, looks like 080711. Best to grab a replacement, or just keep on trucking'
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    You can charge it all you want, and the voltage may even come up into a "normal" range, but it's extremely unlikely that the battery will still have enough capacity to be useable and reliable. ie, it will fail a load test. Batteries have a finite life span and wear out.
    Replace yours and move on.
