2008 Prius dies during water pump replacement at Big-O
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jake Sevins, Aug 1, 2013.
  1. Jake Sevins
    Jake Sevins New Member
    They charged me for the full water-pump replacement including labor and burping. But you're right: they couldn't have burped it since they were never able to turn the car back on.
    I did learn my lesson: at first I thought "well, it's only an oil change" and then when they told me it needed a water pump too, they said "we've done lots of these on a Prius."
    Sigh...
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Lots of discussion on the water pump leak, it is more like a very minor seepage and not usualy serious, before you allow anybody to work on your Prius, do a history search. FIRST. Chances are, the water pump was OK.
  3. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    What a bunch of retards at big O tires. They couldn't even figure out how to jump start a 12v battery. They were probably trying to start it without pushing the brake pedal.
    The computers will continue to talk to a scanner as long as the 12v battery is charged.
  4. Grampienva
    Grampienva Junior Member
    Springfield, VA
    Please, would someone discuss "burping"?
  5. Patrick Wong
    18,200
    6,501
    "Burping", with regards to the Prius engine coolant system, means getting air out of the system. This is not a trivial issue with the 2G engine due to the coolant heat recovery system.
  6. Andyprius1
    2,327
    859
    Cool CA
    I am guessing you may want to bleed the system but also investigate if air is somewhere entering your coolant system? From memory ther are 2-3 bleeder valves. One for inverter coolant and 2 for engine coolant system. If I remember correctly just running the engine with the radiator cap and overflow cap OFF will also remove some trapped air. Pat can update better than I.
    Bleeding coolant / inverter systems can be found in search.
  7. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    If it has run for a few days just check the level in both reservoirs and add as needed
  8. Andyprius1
    2,327
    859
    Cool CA
    It is not that simple, some air will be expelled, but to do it right the engine block and inverter and canister ( if it has one ) all have to be bled, otherwise cavitation can occur. It may seem all right in the Winter, but in Summer the car can overheat severely. The whole process is pretty easy actually.
  9. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    You may be right. Have you actually heard of someone that had the delayed cavitation on the forum or in person or are you guessing it could happen?
  10. Andyprius1
    2,327
    859
    Cool CA
    Yes, on Gen 2s it was verified as happening by Toyota. The inverter pumps were being replaced free of charge. I had replaced mine before the recall and ended up being reimbursed By Toyota. At the time I also did my engine coolant system as well. Air bled both systems. On the Gen 3s, I have not heard of a problem.
  11. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    I know the system is supposed to be air bled during service. Failing to do so can cause an air pocket and pump to cavitation. In this case the engine or inverter over heats on the first long drive. I'm just wondering if an air pocket would hide out and cavitate later as posted above. I'm not trying to split hairs, I'm just curious because I skipped the air bleed on a friends gen 2 Prius engine coolant change. I always thought that if the car is fully warmed up and does not over heat all air has come up. I check that it is fully warmed up by seeing the radiator fan come on. After the complete warm up I check the coolant level once more, add as needed and call it good.
  12. Andyprius1
    2,327
    859
    Cool CA
    . The inverter bleed was easy, the engine bleed is not and requires several engine runs, coolant adds with radiator cap and overflow cap off. But finally I got it. The system will tell you when your off track, In my case I got a couple of spurts of condensation from the right side , so Backed off on the speed and added more coolant. I always considered the Coolant fan running as a sign of overheating, low coolant, hard use, etc. and time to analyse.
