2008 Prius engine clicking sound - 91 Octane gas
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SWprius08, Oct 21, 2016.
  1. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    Hello All,
    So I have been living with this clicking sound from the engine of my prius since last 20,000 miles plus (Currently about 110,000 miles), mostly happens when the load is high on engine, like going up the hill, or increasing the speed on the freeway or even just initial acceleration, and yes the sound became louder and louder over time so I know for sure something is not right, no codes so dealership says nothing wrong. I always used 87 octane gas, but when I experimented 91 octane gas, I found the clicking sound has reduced significantly even the mileage was improved (from 42 to 45), lower engine sound and much smoother ride, so I know for sure the Premium gas played a significant role in the actual issue. Can anyone point to what I should be looking at to make this sound go away? I use Chevron gas and use the Techron liquid every 5000 miles. Spark plugs, fuel injectors, COPS, PCV valve were replaced within last 20,000 miles. Mass airflow sensor also cleaned, throttle body also removed and cleaned thoroughly. Oil change at delalership every 5000 miles. Could it be somewhere in the catalytic converter? Any help or feedback would be appreciated.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I've noticed the same thing on two high mileage 2005's. very common on these cars. I two, would like to know. Like your experience, premium gas made a big difference. Odd for sure
  3. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Do you use gas from the same station all the time?
    If so, switch to another station (Chevron?) and see how their regular octane works....Maybe just be a change in their formulation that your car does not like.\
    Here is an interesting article and he gives some possible solutions toward the bottom, such as a new radiator cap. o_O
    Ping Elimination
    SWprius08 likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Understandable issue. This engine uses solid lifters and unlike hydraulic lifters
    See much more wear, so if your not anal about using high quality engine oil
    The lifter system will see extraordinary wear. The clicking your hearing is lifter
    Slop which ultimately affects engine performance.
    Having the oil changed at the dealer is the death knell for this particular motor.
    You can fix this noise by inserting shims under the lifter taking up to slop but that's very labor
    Intensive. Like I have seen here hundreds of times on posts about clicking
    It would be easier to replace the motor.
    Best bet for a solid lifter motor is using an oil with a zddp additive.
    Most extreme high performance motors use solids as it prevents lifter float
    At high rpm. These motors require high quality motor oil with that
    Additive. Red line motor oil uses that additive and our motor on there
    10-30 version runs extremely quiet. That's what I use. Its a different
    Engine on that oil.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Along what Ed said above, what oil are you using? Think you wanna be 5w-30 on a older Gen2 and maybe a bit heavier if that does not help. Something like Mobil-1 High Mileage 5W-30 might be a bit heavier or go to the RedLine maybe.
    It's hard to tell if it clicking or knocking without hearing it. But sounds like clicking, which is not impacted by fuel octane (use Reg). Knocking is fixed by higher octane, but we are not hearing very many cases where high octane is needed.
    Clicking would be more rythmic and mechanical sounding, knocking is more a chatter during acceleration.
    #5 wjtracy, Oct 22, 2016
    CatsAreGods and edthefox5 like this.
  6. Patrick Wong
    18,210
    6,526
    There is a difference between a clicking sound, and an engine knock/pinging. You first have to decide whether the problem is engine pinging or not. If the symptoms are reduced by using premium fuel, the issue likely is pinging, where there is premature detonation in the combustion chambers due to the fuel/air mixture igniting while the piston is still rising in the combustion chamber. Premium fuel does not ignite as easily, so the pinging is reduced.
    If the issue is pinging, then it is possible that the pistons have built up carbon deposits which result in higher engine compression, thus causing pinging when regular fuel is used. So, if you want the sound to go away, continue to use premium fuel.
    No, it is not likely the problem is in the catalytic converter if the symptoms are reduced by using premium fuel.
  7. SWprius08
    170
    Los Angeles (SFV)
    Yup Premium fuel certainly made a huge difference, actually when my tank of premium completed the MPG was 47 compared to 42 that I was getting with 87, so lets say it is pinging issue, I don't mind using the premium gas, but as I said the sound has reduced not gone away, what can be done to reduce that carbon deposits from the piston without getting into opening the engine etc.? I have seen some engine cleaners at dealership where they ask you to add the cleaner and let the motor run for minutes before changing the oil, should I try that? or should I have them use different oil going forward.
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Well, I am yet sure you have knocking, as high octane should stop it.
    But you might be interested in the recent posts by @chogan2 where he tried heavy doses of Chevron Techron, with apparent success.
  9. SWprius08
    170
    Los Angeles (SFV)
    Before I started using Techron every 5000 miles, I had used techron several times and while it was in the tank my car would run smoothly, next tank without it would go back to the same situation, I read that post and found that he was burning oil, I have not found any burning oil in mine (thank God!), using 91 reduces the issue by 80% I would say does not completely go away.
  10. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    My 08 is bad for this (480,000Km)
    If its the same noise that I think it is, it has nothing to do with lifters Patrick is correct Its pre ignition aka detonation or "ping" caused by carbon build up on the piston tops, good fuel ignites later so it shifts the "spark" away from the areas of most carbon.
    I find it to be much worse on hills if the battery has low soc as the load on the ice is much greater when the battery is low, if I hit a hill with the battery in the green it pings much less than if the battery is low.
    the better the fuel the less it pings, if I buy ultra premium 98oct fuel the ping almost goes away completely, if I buy 91 it pings so bad you think your engines going to self destruct
    cosminman likes this.
  11. orenji
    orenji Senior Member
    5,887
    3,490
    Could the knock sensor be bad?
  12. Mendel Leisk
    42,355
    Higher octane not so much "better" fuel, just harder to ignite, so more suitable in higher compression engines. Or older, regular compression engines with lots of carbon build-up.
    ozmatt likes this.
  13. ozmatt
    637
    263
    Australia
    Yeah sorry I didn't want to go off on a rant about octane ratings. better fuel = more octane.
    requires more combustion to ignite = shifts the explosion slightly away from the carbon build up
    another thing i noticed my 08 pings way worse on non ethanol fuels than it does on 10% ethanol of the same ron rating
  14. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Not really surprising seeing as in NZ, Aust, UK and EU the Gen II is supposed to run on 95 RON minimum (89-90 AKI in the USA).
    I second the comment of your illogical emotive language that low RON equals bad and higher RON equals good. RON rating has only to do with using the correct rating for which the engine is designed. You can use higher octane rating without problem (except a lighter wallet), but you can't (or at least shouldn't) use a lower octane rating.
    #14 dolj, Oct 24, 2016
    ozmatt likes this.
  15. ozmatt
    637
    263
    Australia
    I see posts on here suggested prius was designed to run on low grade 89 gasoline :)
    But I never realised, or even cared to notice that US fuel is metered on the AKI system rather than RON, thanks very much for the tip Dolj .. does this mean US 89 AKI is around the same bang as AU/NZ 95 RON ?
    using "too higher" rating octane can cause overheating, been known to blow head gaskets be careful with that
  16. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    In the US, all Priuses are rated for 87 AKI, which is roughly equivalent to 91 RON, for what it's worth.
    And I had always seen that it was 91 AKI that was closest to 95 RON. (Note that in many parts of the US (west coast, high altitude, some major cities elsewhere), 91 AKI is the most you can get.)
    ozmatt and wjtracy like this.
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    @bhtooefr has it correct re: octane...It's a little hard to imagine a lot of carbon on a Ca. clean gasoline at 100K miles, but I suppose it is possible as @chogan2 had a similar issue here in NoVA where we also have RFG gaso.
  18. SWprius08
    170
    Los Angeles (SFV)
    Yes, I think we both are talking about the ping, and yes I have felt the same way when the battery is low (mostly when AC is turned on high in summer) and I try going uphill that the noise is so loud that it feels something will break. Other than continue using higher octane (91 AKI is the max that is available here), have you done anything else to fix this ping?
    ozmatt likes this.
  19. orenji
    5,887
    3,490
    I would have the knock sensor inspected/replaced it could be failing.
  20. orenji
    5,887
    3,490
    Per our manuals in the USA it states that we can use 87 or higher octane, so if higher octane would harm the engine, I would think Toyota would state otherwise. I only use 91 in my Prius.
