2008 Prius - Engine Light Check/Red Exclamation Mark - 12V Battery OK
Discussion in 'Gen 2 Prius Main Forum' started by SRK444, Jun 10, 2013.
  1. SRK444
    SRK444 New Member
    Austin, Texas
    Hello All:
    I've been using my prius 2008 very smoothly till today. It was 100F+ in Austin and very hot. The car, suddenly lit up all the warning lights: Engine, Red Exclamation, Hybrid, and brake lights. The brakes kept beeping on both sides. I also heard an engine noise that is quite uncommon for prius. I stopped the car in a parking lot.
    I came back in an hour and tried to start the car. I only saw 2 lights now: Red Exclamation, and Engine check. It might some "click" noise when I started, and after that it was fine. I drove for a while and everything was fine but the 2 warning lights were still on. I tried starting and stopping few times. I did experience the clicks (1-2) and the engine noise. The engine noise lasted 15-30 seconds and then it was back to normal.
    I followed the youtube video to look up the diagnostics (Display pressed + lights on/off 3 times) to check the 12V battery. It read 13.8 V. I recently had an oil change at Toyota dealership less than 500 miles back. So I am baffled at this point. I have about ~60K miles and it's a 2008 model. So if it's a hybrid battery issue, I am covered but I want to see if any experts have any light to shed on this.
    Thanks in advance for your time and help.
  2. Patrick Wong
    18,210
    6,526
    See if the inverter coolant pump is running: make the Prius READY, open the hood, then look for fluid turbulence within the inverter coolant reservoir. If you do not see turbulence, the pump has failed and that is the root cause of your car's problems.
    If you see turbulence, then your car has another problem.
    The condition of your car's 12V battery is unknown at this time based upon the test you described. Your measurement of 13.8V shows that the DC/DC converter within the inverter is working. That says nothing about the 12V battery condition. What is needed is to determine the battery voltage when the Prius is not READY, ideally after the car has rested unused overnight.
    cwerdna likes this.
  3. SRK444
    SRK444 New Member
    Austin, Texas
    Thank you Patrick.
    I checked the battery this morning and it read 13.9V on the diagnostic window. Can I now assume that the 12V battery is fine?
    Also, I checked the coolant reservoir. I heard a huge engine noise, so it was hard to tell if there was turbulence in the fluid. I did see the fluid move but when I turned it on and off few times, the engine noise went away but I didn't see any visible turbulence. Does that mean the pump has failed?
    We're thinking about calling Toyota dealership this morning. Is there something else that can be done or is calling them the best way forward?
    Thanks for your help.
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    You're still checking the battery in the READY mode, while it is being charged. It has to be checked while not in READY mode, so it is not being charged. Go back and re-read the instructions, without the brake depressed. You need all three readings.
  5. Riaz
    Riaz Junior Member
    31
    Georgetown, Guyana
    Hi SRK444,
    To do an effective test of the 12v battery you need to test it with a DC voltmeter with the car completely off or in accessory mode (single press of power button without depressing brakes) and with some electrical load on eg the headlights. The measured voltage with the headlights on should be higher than 12v and should not be dropping quickly for a good battery.
    However, based on your indication of a strange engine sound I doubt the 12v battery is the problem. I have driven my 06 Prius with a near flat 12v battery that was bearly able to get the car into ready in the morning and the car drove fine without any warnings...but every case is unique so you can't rule it out completely.
    I'd take it to the shop to have it checked out...it's possible that the engine is overheating and the strange sound you're hearing is the radiator fan kicking in but that's just speculation...you need to get the codes read at a shop for a proper diagnosis. Hope it's just a minor problem...good luck!
  6. Patrick Wong
    18,210
    6,526
    Contacting your dealership is probably the best action plan at this time, since it sounds like you need a new inverter pump. This is covered under a recall program for older 2G Prius, so if your car is not covered just pay the bill and then write to the Toyota Customer Experience Center for a refund.
  7. SRK444
    SRK444 New Member
    Austin, Texas
    All,
    Thank you very much for your efforts to help. So it finally turned out to be the AUX battery, and couple of other things (I have to check the paperwork) that were under recall. They only charged us for the battery which was around $300. I'll post the detailed problem from the paperwork sometime soon. Thank you all again.
  8. bisco
    52,863
    glad you're sorted out, all the best!(y)
