2008 Prius, engine wiring harness help
Discussion in 'Gen 2 Prius Main Forum' started by Samuel.20, Jul 13, 2018.
  1. Samuel.20
    Samuel.20 New Member
    US
    I have a 2008 prius and I am trying to switch out the engine wiring harness, but I cannot seem to get it out. Most of the plugs are unplugged, however, I cannot seem to detach the harness from the firewall behind the engine. Does anyone have a tutorial/any ideas on how to do it? Any help is much appreciated.
    52,863
    welcome!
    you can find the service manual on line, with complete detail at toyota tech info.com
    all the best!(y)
  3. ChapmanF
    19,035
    ... or at some rather similar URL like this one: techinfo.toyota.com
    I wonder if bisco has registered "toyota tech info.com" and put up a lookalike site there to steal everybody's identities.... :)
    -Chap
    52,863
  5. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Are you trying to remove the entire harness from the hood?
    You got to detached all the wire connectors from the sensors, etc, and try removing the manifold that gets on its way.
    Don't you have a manual?
