2008 Prius Gas bladder
Discussion in 'Gen 2 Prius Main Forum' started by Terri Bolt, Apr 24, 2018.
  1. Terri Bolt
    Terri Bolt New Member
    Is there a fix for 2008 Prius Gas bladder not taking a full tank and spewing gas out?
  2. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Pump the gas at a slower rate and hold the filler nozzle at an almost 90º angle to the vertical with the the nozzle just inside the filler neck (the narrow part). Listen carefully and when you hear the gurgling sound of the fuel rising in the filler neck, back off to the slowest you can go so the gurgling backs off. Stop after the auto cutoff activates.
    #2 dolj, Apr 25, 2018
    WilDavis likes this.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Any idea why that works?
    Why do we hear the filler neck filling up if the tank has more capacity?
  4. dolj
    dolj Senior Member
    8,633
    4,386
    No, sorry. I have no idea why we can hear the filler neck filling up, I just know it works and mine doesn't have the bladder, so it is something else other than that. Something to do with the way the tank is designed as the fuel goes in and air comes out, I suppose. It is the most finicky tank to fill I have come across.
    #4 dolj, Apr 25, 2018
  5. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Does "spewing gas out" mean that you are trying to put 12 gallons in your car when there is already a gallon or two in there? When I have one pip flashing on my 2005, I can rarely put more than 9 gallons in there.
  6. bisco
    52,772
    can you fix your car info? instead of 'prime plus', put in what package you have. thanks!(y)
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    OK but we may have a bladder problem on top of that. It seems better in summer when the bladder may be warmer and more flexible, but also in the U.S. they take the butanes out in summer fuel, and that change seems to help also.
  8. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Put the pump all the way in and put the metal click tab on. Hold the pump in one hand and the gas cap in the other. When the pump clicks off pull it out with one hand and put the cap on with the other. You might spill a little but not like if you were just sitting there watching it pour back out.
  9. bisco
    52,772
    remove the tank, remove the blatter, replace the tank, problem solved.;)
  10. Erik Owens
    Erik Owens Member
    162
    59
    Alright has anyone thought about either your evaporative vent valve sticking close? If it does and no venting you will not be able to take gas and yes your fill neck could be clogged as well. Another idea is that you recently fueled on an incline and the inclinometer sensors of your combo meter that talks to the fuel gauge is out of calibration? I have heard that but never seen it since most gas stations are pretty level. Spewing out like that means it is not venting and pushing the fuel back out because air is not being displaced when liquid is entering bladder. You are right as well the plastic resin outside is concealing a bladder inside when cold or hot will take varying amounts of gas depending on season. Hope that helps,.....SCIENCE! Plus I am a mechanic so yeah.
  11. bisco
    52,772
    all this spring and venting is making me hungry.
