2008 Prius gas gauge drops to one bar with gas tank 75% fuel.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by livinin82, Jan 14, 2017.
  1. livinin82
    livinin82 New Member
    US
    The first time this happened I came home from work with an almost full tank, turned off the car, went to bed, and when I got in my car the next day the gauge had one bar and I got the Add Fuel message. I went to a gas station and did the inclination reset and filled up and it was fine.
    A week later I'm driving with about 2 bars less than full and when I'm on the interstate it drops to one bar...Then 15 minutes later goes up to half full.
    Any insight, guys?
    EDIT: I filled it up with 2.49 gallons and it is reading full again but how can I prevent this?
    51,076
    yes, it's likely the rubber bladder inside the tank. it is affected by the climate. best you can do is reset the trip meter and fill up after 500 miles or so, sending on your average mpg's.
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I just did this fill tank remove 12v battery for 10min it will be a little off because of the rubber tank liner and wintertime best times the summer
  4. Moving Right Along
    Moving Right Along Senior Member
    699
    546
    Maybe you have a bad fuel sensor or a problem with the fuel bladder
  5. livinin82
    US
    Was this a long term solution?
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  8. livinin82
    US
    Is there a different method than the inclination reset? Or is that the same thing?
