2008 Prius Goes into ACC mode by itself
Discussion in 'Gen 2 Prius Main Forum' started by Ryansb13, Jan 22, 2018.
  1. Ryansb13
    Ryansb13 New Member
    I have a 2008 Prius and it has started going into ACC mode on its own. My Prius requires the key fob to be in the dash in order to start, but the car has started going into ACC mode with having the key fob in. It has happened a couple time after I have turned the car off, pulled the fob out and started to get out of the car. Yesterday it happened in my garage and now my battery is dead.
    My 12v battery is relatively new... maybe 3 months old. I have seen other people post on this, but haven’t seen any solutions. If anyone has any ideas I would appreciate it.
    52,862
    welcome!
    could be a problem in the fob slot electronics, low fob battery, defective 12v, loose 12v wiring, time to start eliminating the low hanging fruit.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Here's what I'd try first (free and easy to do): check the brake light switch operation. With the car on, rest you foot on the brake pedal and see if the lights activate. If not, gently press the pedal until it does. The adjustable switch may be out of spec. so the car may not be recognizing the brake is being pressed during the power down phase and going to ACC instead when the power button is pressed.
    edthefox5 likes this.
  4. Ryansb13
    Ryansb13 New Member
    Bisco,
    Thanks for the suggestion. When you say “loose 12v wiring” are you think the connection to the 12v battery or somewhere else in the system?
    Thanks
  5. bisco
    52,862
    yes, the positive and negative connections at the battery, and also where the negative connects to the body. inspect for corrosion as well.
    and to fotomot's point above, if you have your foot on the brake when pulling the fob out, that may be an issue.
    Ryansb13 likes this.
  6. Ryansb13
    Ryansb13 New Member
    I see what you mean, but I’ve already removed the key fob at this point and I can’t remove it until I have completely turned it off. Does that make sense?
  7. Ryansb13
    Ryansb13 New Member
    I’ll look into that first. Thanks
  8. fotomoto
    5,639
    3,815
    So. Texas
    Only one key fob? Does the issue exist with others?
  9. Ryansb13
    Ryansb13 New Member
    The positive connection to the 12v battery was loose. I tightened it and now I’m hoping the problem is solved.
    Thanks for the help and I’ll try and update this post in a week or so to confirm if the problem was solved by tightening the connection to the 12v battery.
    valde3, Prodigyplace and fotomoto like this.
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    Be sure you have more than one key fob. It is much easier and less expensive to add one if you have a working fob.
    It usually requires more expense & dealer reseeding if there is no good fob.
    Some people have found the negative connection to the body loosens too.
  11. Ryansb13
    Ryansb13 New Member
    Where do you recommend getting a new key fob from?
  12. fotomoto
    5,639
    3,815
    So. Texas
    Amazon, ebay, etc., approx. $100 for a NEW fob is considered a decent deal. Dealers are usually MUCH more. Do not buy a used one; they won't pair. If you lose the last remaining FOB or it stops working, you'll have a MUCH more expensive problem on your hands (dealer/locksmith).
    With a new FOB, you pair it yourself to the old FOB/car by doing the chicken dance: How to Program a New Key Fob for Full SKS Functionality | PriusChat
    #12 fotomoto, Jan 22, 2018
    Ryansb13 and Prodigyplace like this.
  13. Crews Family
    Crews Family New Member
    Alabama
    @Ryansb13-
    Did the loose connection fix your random starting car?
    My 2008 Prius has 206481 miles and has decided to start turning on by itself.
    It also does the no dash lights most of the time when I go to start car.
    Sometimes it’s like it has no battery power and will do nothing. Sometimes when you shut the doors it will then have battery power again and inside lights will light up.
    If the dash does not light up it does not like to turn off! Cruise control does not work either when the dash does not come on. I did find a thread that says to hold down the power button without your foot on the break until car cuts off. Sometimes it works but most of the time the car motor stops but everything else is still powered up. I then have to double mash the power button to power everything down.
    Love my car but it’s driving me crazy!
    Help any suggestions on all this craziness going on?
  14. ChapmanF
    19,033
    In my understanding, when the combination meter stops working right (a known issue involving a capacitor), it stops doing its needed steps in the dance of powering off the car. So you may find that fixing the combination meter issue will fix the powering-off issue.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    +1 to ChapmanF.
    Your symptoms certainly sound like a faulty CM (combination meter- speedometer- instrument cluster). You might want to read the "sticky-ed" at the very top of the Gen2 Care, Maintenance, and Troubleshooting forum.
  16. Steve Lavsa
    Steve Lavsa New Member
    pe
    Ever get a resolution to this? There are a bunch of these posts and the only thing I ever see is tried tightening battery connection and no follow up. (Hey maybe that means it worked).
  17. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Why don't you try it? Then you can post back with a resolution to all the threads you've resurrected.
