2008 Prius HID to LED Conversion
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jesse Floyd, Feb 25, 2017.
  1. Jesse Floyd
    Jesse Floyd Junior Member
    South Carolina
    I am new here so don't judge me.
    I recently started researching on how to convert my factory HID headlights on my Prius to a pair of LED headlights. I have not had very much luck, and the cheap ones I did buy proved to be incompatible even though the seller told me they would fit. Since then I have been trying to find out the headlight connector type on my Prius. Attached is the connector from the new LED headlights I bought, as well as the connector from the car itself. Even when I look on amazon and eBay, these same headlights show that they will fit with my car! Is there some connector I am missing? Do I have to dig deeper? Or are these headlights really incompatible with my car. I am trying to spend $50 or less (Long shot I know) on these headlights as I have already had to shell out money for 3 replacement HID headlights for my car, and from what I understand, LED's have a much longer life and are generally brighter. HELP! HID connector.jpg LED connector.jpg
  2. Spaysship24
    Spaysship24 New Member
    US
  3. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    I'd like to say that the LED connector replaces directly the connector pins of the light bulb, because it looks same.
  4. Jesse Floyd
    South Carolina
    I would say so as well, but as my post indicates, I have HIDs and not halogens
  5. Jesse Floyd
    South Carolina
  6. Jesse Floyd
    South Carolina
  7. Jesse Floyd
    South Carolina
  8. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Is there a silver connector Shield on your connector that covers the plug those are HID if you just have a standard connection your halogen
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  10. Jesse Floyd
    South Carolina
    Yes sir, I know that they are HID as I have ordered them before, and the hue of the light is blueish
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Then find the 12v to the High voltage HID and hook it to 12v blub then find the 12v for the high bean hook it to the blub ground the last pin to chassis it will be like 30% dimmer that why they upgrade to HID
  12. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The real Philips brand HID bulbs in my 2006 (D4R) have lasted almost 9 years now. The originals didn't make it to 2 years. There was a run of bad ones on 2006 Prius with HID. The originals were short life, but the replacements have been excellent.
    Wear gloves when touching the glass or the skin oils will damage it. Better yet, just don't touch the glass.
    There may be other brands than Philips that last, but I don't know any. There's a reason the Philips go for $50 each. The $15 ones use cheaper materials and it shows.
    If you think $50 is steep, the original dealer price was $300 each. More than a few new owners were really pissed paying 2 X $300, plus another $250-$300 for installation. Legal action cut the price to $150 each, although dealers still insist that you have to remove the bumper and headlight assemblies for 2+ hours labor.
    Here's the classic video of Luscious Garage mechanic Carolyn Coquillette replacing a bulb in 3 minutes...
  13. Jesse Floyd
    South Carolina
    I know how to replace them, and I know the price. I just want the LED headlights because they are brighter than the HIDs and they look cool and last a long time
  14. DenisKoma
    DenisKoma New Member
    Three Touring
    Hey Jesse, any joy with the LED conversion? I am thinking of doing the same thing so I would appreciate if you could shared any progress with me.
  15. Jesse Floyd
    South Carolina
    No joy, from my research, I have found that these conversions are easy for halogen models, i am still researching but it may have to be done with diy wiring and that isn't my speciality
  16. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    If you want to stay cheap buy brighter HID bulbs. Factory color is about 4300K warm color so try a 5000K or 6000K hid bulb. Higher numbers are too blue for me. Find some super cheap ebay $5 bulbs to play with different hues until you find what you like. I had green headlights at one point.
    You other route is possibly going to need 1. Set of non HID Prius headlights. Your HID headlights sockets/bulb mounting area can only hold an HID bulb. Compare HID bulb D4R to 9003 of the non HID Prius. 2. A 9003 LED bulb that is plug and play. Most high powered ones suggest not using for any headlight that has a cover over the bulbs like ours. They have a heatsink on the back which gets hot. Light output may be scattered as high power led bulbs are typically only pointed two. directions on a board vs HID that spreads evenly. A projector retrofit may correct light scatter. 3. Wiring harness with fuses to be safe or at least pigtail adapters to connect power to the new style 9003 bulb. Not to mention messing with the high beam wiring.
    Sweet idea and came across your post as I'm debating on swapping to LED bulbs on my 06 with standard bulbs despite the suggestions saying not to due to the back cover. Put some LED bulbs in my fog lights cause there is no back cover or gaskets and it's way brighter. There is some scatter which is OK because my headlights blend the coverage.
  17. Petrodollar
    Petrodollar Member
    53
    46
    Four Touring
    Are these the types of lights you are looking for? These are supposed to be LED lights for replacing D4R HID lights. I think they replace the HID light and inverter / ballast. So the LED lights plug into the 12V line which normally goes to the inverter / ballast. Some kits will have the same connector and plug into the original 12V connector, while other kits require you to splice into the original 12V line.
    Some types have the current driver built-in to the base, others have a current driver in-line with the 12V cable (sometimes called a power brick).
    SNGL Super Bright LED Headlight Conversion Kit - Adjustable-Beam Bulbs - D2S ( D2R D4S D4R ) - 110w 12,400Lm - 6000K Bright White - 2 Yr Warranty
    55W 6000K 6200lm Philips Lumileds LMZ7 2pcs $179 (Amazon SNGL Automotive Lighting)
    LASFIT D2S D2R D4S D4R D2 D4 LED Headlight Bulbs-High / Low Beam 72W 7600LM/set 6000K Cool White-1x Pair(2pcs)
    LAD2 9-16V 36W 6000K 3800lm 30Khrs Philips LEDs 2pcs $80 (Amazon LASFIT)
    D4R LED Headlight Conversion Kit
    6-24V ?W 6000K 4000lm 60Khrs Philips Lumileds ZES 2pcs $100 (Headlight Experts NV, USA)
    2x D4R 1000W LED Headlight Conversion Kit 6000K Bulb
    12V 6000K Bridgelux COB LEDs 2pcs $20 (eBay 322927146933)
    (D4R LED Headlight Conversion Kit) Headlight Experts
    (2x D1S D2S D3S D4S D1R D2R D3R D4R 1000W LED Headlight Conversion Kit 6000K Bulb | eBay)
    #17 Petrodollar, May 2, 2018
  18. Petrodollar
    Petrodollar Member
    53
    46
    Four Touring
    Here are examples of a few more D4R HID to LED replacements with a range of prices.
    Two have a current driver built-in to the molded backshell of the connector rather than in-line with the cable or in the base.
    No endorsements are implied and the ordering does not imply any preference.
    See this recent 2018 thread for a successful conversion:
    HID to LED conversion
    https://priuschat.com/threads/hid-to-led-conversion.189769
    It went well, except the particular LED used has a problem with FM radio interference from the current driver. So I wouldn't use that particular model.
    11-30V 55W 6000K 6200lm 50Khrs Philips Lumileds 2pcs $204 (eBay 142629677431)
    (SNGL Super Bright LED Headlight Conversion Kit - Adjustable-Beam Bulbs - D2S ( D 706238635440 | eBay)
    C6F Fit All D4S D4C D4R 72W 7600LM/Set Flip Chip LED Kit Low Beam Headlights
    12V 36W 6000K 3800lm ?Khrs 2pcs $66 (eBay 262897633339)
    (C6F Fit All D4S D4C D4R 72W 7600LM/Set Flip Chip LED Kit Low Beam Headlights | eBay)
    LED Kit 7S 50W D4R 6000K White Head Light Two Bulbs Retrofit Bi-Xenon Upgrade OE
    12-24V 50W 6000K 6000lm ?Khrs Philips Lumileds ZES 2pcs $62 (eBay 142682317463)
    (LED Kit 7S 50W D4R 6000K White Head Light Two Bulbs Retrofit Bi-Xenon Upgrade OE | eBay)
    2x D4S D4C D4R 6000K White 1200W 180000LM LED Headlight for Philips/OSRAM Bulbs
    9-32V ?W 6000K ?lm 50Khrs Seoul SZ8-Y19 LEDs 2pcs $50 (eBay 263546428416)
    (2x D4S D4C D4R 6000K White 1200W 180000LM LED Headlight for Philips/OSRAM Bulbs | eBay)
    2x D4S D4R D4C 6000K HID White Replacement Lamp Bulbs CREE CSP LED Headlight Kit
    9-32V ?W 6000K ?lm 50Khrs Seoul SZ8-Y19 LEDs 2pcs $50 (eBay 122704677944)
    (2x D4S D4R D4C 6000K HID White Replacement Lamp Bulbs CREE CSP LED Headlight Kit | eBay)
    LED Kit X3 50W D4R 6000K White Head Light Two Bulbs Retrofit Bi-Xenon Upgrade OE
    12-24V 50W 6000K 3000lm ?Khrs Philips Lumileds ZES 2pcs $45 (eBay 142633333284)
    (LED Kit X3 50W D4R 6000K White Head Light Two Bulbs Retrofit Bi-Xenon Upgrade OE | eBay)
    920W Car CREE D4S D4R D4C LED Headlight KIT 6000K White Bulbs High Power
    12-24V 40W 6000K 4800lm 30Khrs Cree LEDs 2pcs $37 (eBay 112212812242)
    (920W Car CREE D4S D4R D4C LED Headlight KIT 6000K White Bulbs High Power | eBay)
    D4S D4R D4C 6000K HID White 620W 74400LM Fanless CREE LED Conversion Headlight
    12-24V 40W 6000K 4800lm 30Khrs Cree LEDs 2pcs $36 (eBay 262538079906)
    (D4S D4R D4C 6000K HID White 620W 74400LM Fanless CREE LED Conversion Headlight 603432738376 | eBay)
    #18 Petrodollar, May 3, 2018
  19. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
  20. Lloyd-ss
    Lloyd-ss Member
    97
    93
    Ivy, VA
    Four Touring
    This post might be too late for this topic, but here is a link to the step-by-step on how I converted my 2007 from HID to LED.
    It was a learning process for sure, but in the end, worked out great.
    HID to LED conversion | PriusChat
