2008 Prius New Stereo
Discussion in 'Gen 2 Prius Audio and Electronics' started by Falco78, Oct 17, 2018.
  1. Falco78
    Falco78 New Member
    Winchester, VA
    Well my 2008 Prius which I just purchased this week will be getting a new stereo in the next few weeks. I am going to start with the head unit only before later moving onto the speakers and sound deadening. After the head unit is installed I will later look to add my MB Quart ZA2-1600.4 4 channel amp and front and rear PPI P65C3 3 way components along with sound deadening of the doors.
    - Pioneer AVH4400NEX (got it off of a car audio forum for a steal)
    - Sirius XM module for radio above
    - Metra TYTO-01
    - Metra 95-8240B
    - Metra 70-8114
    - Metra Axxess ASWC-1
  2. Robert in Sahuarita
    Robert in Sahuarita New Member
    17
    Sahuarita Az
    2003 Prius
    I just put a pioneer mvh390 in mine.
    I wired the radio direct from the harness.
    The only piece from the mounting kit i used was the faceplate trim.
    I also wired in a small kicker 4 channel amp and an audiopipe apmi 2000 and a pair of skar audio 8's.
    I got rid of all the jbl "premium " sound. I have been using the stock jbl tweeters as i havent got around to installing the rest of my components. Not impressed at all with the stock tweeters.
    It was a pain to find the pinout of the radio.
    Sound deadening is next on my list, and definitly has to help.
    Im running a regular 12v group 51 battery.
    The difference is amazing. I considered trying to use the stock head unit, but I am extremely happy i didnt.
    I used the trim piece to mount a switch so my son can watch dvds, and am in the process of wiring a switch and some diodes so i can turn on my aftermarket backup camera at will without turning on the reverse lights.
  3. Robert in Sahuarita
    17
    Sahuarita Az
    2003 Prius
    Also to note, i mounted my midrange amp under the passenger seat in place of the jbl amp. I ran new wire to the front speakers, but i personally felt the stock wire was ok for the rear speakers and tapped into that. The rear doors use a molex plug mounted on the chassis and the wires from the door plug into that. I didnt feel like messing with working around that.
  4. Falco78
    Falco78 New Member
    Winchester, VA
    The amp I have due to size will have to mount on the rear seat backs and I will run all new wiring as 200 wrms per the 4 channels I don't want to use the junk factory wiring.
  5. Falco78
    Falco78 New Member
    Winchester, VA
    Yeah headrest monitors will be coming after Christmas is over so my kids can watch movies while I drive.
