2008 Prius no Dashlight
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Oct 28, 2021.
  1. richard203
    richard203 Member
    279
    61
    SF
    hi so i was doing something on my prius and all of a sudden my dashlight dont work. my reverse dont work, turn signal dont work but my harzard light works. did I pop a fuse?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    What were you doing before it stopped working all of a sudden?
    Have you checked the fuses?
    What is the 12v battery voltage when measured at the jump points under the hood?
  3. richard203
    richard203 Member
    279
    61
    SF
    I was checking on some relay, I think I pulled out the HTR relay inside the driver area and the PHTR in the engine bay area I think thats what it called
    i checked the back trunk battery 12.3v i think
    I checked the inside driver side fuse box the panel and tail light fuse do not have 12v mybe 5v? i pulled out the fuse and it wasnt blown
  4. richard203
    richard203 Member
    279
    61
    SF
    looking at a wiring diagram the only relay that connect Panel and Tail Fuse is T-LP Relay but it dont show wheres the T-LP Relay located
  5. richard203
    richard203 Member
    279
    61
    SF
    the panel and taillight fuse is only getting mv and the engine bay DIM fuse is not getting any voltage too. do you think i poped the fuseable link? front window dont work too
    #5 richard203, Oct 28, 2021
