2008 Prius not responding to key fobs!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan Ramos, Mar 24, 2025.
  1. Ryan Ramos
    Ryan Ramos New Member
    UK
    Excel
    Hi all, I have a bit of an issue:
    A couple days ago after getting into the car, it wouldn't respond at all to the fob for about 10 minutes before suddenly turning on with a system loading notification on the screen.
    Now, it's a reoccurring issue. The fobs can't even lock/unlock the car. I've changed the batteries on both my fobs and no change. All the videos I see online are based around a dead fob battery or a the dashboard lights coming on. The car isn't responding at all to any key. Any advice? Car Batteries have been serviced and all is well.
  2. Brian1954
    Brian1954 Senior Member
    2,551
    1,010
    South Central PA, USA
    Use a meter to measure the voltage of the 12v battery when the car is off. What voltage do you read?
  3. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    While you have the voltmeter out, check the voltage of the fob batteries, too.
  4. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    When you insert the key fobs into the slot on the panel to start, nothing happens either?
  5. Tombukt2
    Tombukt2 Senior Member
    13,738
    2,486
    Durham NC
    So you have a red light flashing on the dash in the shape of the key? When you insert your fob that flashing light should stop does it?
  6. Tombukt2
    13,738
    2,486
    Durham NC
    Does the physical key in both the fobs turn the lock on the driver's door?
