2008 Prius - P0A37 code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joshua Gaynor, Mar 1, 2023.
  1. Joshua Gaynor
    Joshua Gaynor New Member
    Rhode Island
    I am having a not-so typical issue with my 2008 Prius. Wife was driving 60 miles back home from her job and code P0A37 comes up (Red triangle, VSC, (!) Brake warning) and she is forced to pull over and immediately power cycle the car in order to gain access to the ICE again. This happens about once a month on 60 plus mile trips only; this is the fourth time. This is explained as either the sensor inside the transaxle going faulty, or the transmission overheating. I have drained and refilled four quarts of OEM ATF 20,000 miles back… but then it dawned on me… aren’t our Prius transmissions liquid cooled?
    I have ”little, to zero” coolant oscillating in the inverter coolant reservoir. However I have not gotten a code to replace the inverter coolant pump yet… figuratively… if my pump hasn’t failed yet, but was on its way out, could this be causing my transaxle overheat sensor to trip on long distance driving since there isn’t adequate cooling for the transmission? I theory crafted this myself and cannot find much support for my theory online. Since this has been going on for so long I highly doubt my transmission is the culprit, wouldn’t it decline rapidly? What are your thoughts team?
  2. Tombukt2
    Tombukt2 Senior Member
    13,885
    2,521
    Durham NC
    You say you don't see inverter fluid moving in the inverter reservoir. But is the inverter reservoir filled with the pink stuff to the full line. If you touch that reservoir after a good run is it warm like higher than your body standing temperature 100° 104? It should be then you can touch the hoses coming out of the bottom of the inverter just a head towards the front of the car of the reservoir that fitting should be relatively warm not overly hot but certainly not cold and then over by the inverter pump both hoses coming in and out of the pump again should be warm 104 to 112° or something like that after a decent run.
  3. Tombukt2
    13,885
    2,521
    Durham NC
    I think you're mixing up inverter cooling which is the silver box on top of the transmission that charges your HV battery versus the transmission itself getting cooled or the transmission fluid.
    52,927
    Top up the fluid and see what happens
  5. Joshua Gaynor
    Rhode Island
    Correct, I don’t see any movement inside the inverter coolant reservoir. I am topped off at full. I believe I read that the coolant on the inverter coolant circuit goes through the transmission at one point to cool it. So if I’m not getting enough movement from a failing pump I would think it could cause this issue. It has been 40 degrees out for the past couple months if that means anything. Going to drive home from work later/ I will test temperature in reservoir to see if it’s around 100… at any rate it’s odd that I’m getting a P0A37 instead of a 93… I’m also going to check my ATF level since that is all Toyota would do before telling me I need a new motor.
    Color me confused because when people get this code their tranny degrades rapidly and the triangle comes up more and more often. This is not congruent for my case.
  6. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    There isn't a code that sets "to replace the inverter coolant pump". There is a code for when the inverter is not being cooled effectively - P0A93. It just so happens that more times than not the inverter is not being cooled effectively because the pump failed. It is not unheard of for the inverter coolant pump to fail but not throw a P0A93 code. You just need to confirm you have power at the plug to the pump but the pump is not running. It is quite easy to hear and feel if the pump is running or not.
    Definitely.
    #6 dolj, Mar 2, 2023
  7. Tombukt2
    13,885
    2,521
    Durham NC
    When you're in the trip condition and you have this light or this code pop up if you pull over and touch the pipe the metal pipe coming out of the bottom of the inverter just a head towards the grill of the car of the reservoir for the inverter touch that pipe go across to the left headlight get behind the left headlight and touch the two hoses from the inverter pump in and out are they about the same temperature let's say around 110° or less something like that? In 40° weather in my '09 I could probably drive for 3 hours that would be from where I live in Orange county North Carolina to Charlotte 300 miles almost before that light would come on at those temperatures now when it's 75° in the spring that'll come on in 45 minutes maybe less during these conditions. I drove around without an inverter pump with a new one sitting on the floorboard for a couple of weeks at the end of winter coming into spring to see how long I could drive with that coolant not pumping etc It seems that the coolant would still move a little bit just because of the effect of the coolant getting warm and rising or something No it wasn't circulating like it was being pumped but it was still moving. So it rarely tripped the light and did anything until it got much warmer and then I changed over to a completely different style pump and I haven't thought about it since it just works.
  8. Joshua Gaynor
    Rhode Island
    Fascinating, so you had this code come up and it turned out your inverter pump was not operating up to spec? This gives me hope that my transmission isn’t kaput. In a few hours I’m going to be checking the ATF level and seeing if the reservoir container is around 100 degrees after a thirty minute drive. If I do need a replacement is OEM the way to go? You said you got an entirely different style and that intrigues me
  9. Tombukt2
    13,885
    2,521
    Durham NC
    No I didn't have a code or I don't remember what it was if I did what happened in my situation when the thing finally overheated got hot enough outside and the conditions were just right It turned the green car red on the MFD and I knew immediately when I saw that that the inverter pump was not pumping or something and I got out and checked the inverter pump and sure enough it wasn't running not able to run was getting power through the plug just not working That's all I was saying.
  10. Joshua Gaynor
    Rhode Island
    Just checked the ATF fluid level and it was still pink and up to the proper level. Seems it’s not burning/leaking ATF fluid
  11. Tombukt2
    13,885
    2,521
    Durham NC
    You're in Rhode Island correct so it should still be fairly cool there seriously unless you're flogging down the highway at pretty good speed 65 etc You shouldn't be able to overheat anything in the weather that should normally be in Rhode Island this time of year you'll actually have trouble having good heat I'm just joking but generally that would be more of a problem than making an overheat condition I mean unless your thermostat is slam shut completely and you're trying to set speed records I would say Heat in Rhode Island at this time of year wouldn't be it. And quickly flogging up the hood after a good run touching all your coolant hoses for the inverter and the regular radiator should yield no problem to hold ie no high temperatures to make your hand move nothing to worry the car at all.
  12. Joshua Gaynor
    Rhode Island
    GREAT news. Seems my hypothesis was correct. The code finally came up. The wife was driving it home from work and boom. Time for a new inverter pump. Glad that was the problem. About to order an OEM one and call it a day.
  13. edsai
    edsai Junior Member
    Indiana
    This just started happening on my 09. I bought 4 qts of atf ws to do a change thinking maybe I have a leak and I’ll find out once I pull the fill plug off.
    When I pulled the fill plug off, about 4 qts of atf ws emptied out. When I pulled the trans drain plug, another 4 qts came out. I had the drivers side cv axle replaced 9 months ago and the mechanic said my atf was low and had to add a couple of quarts but didn’t charge me.
    I had them replace the inverter coolant pump a year preemptively but now I’m wondering what caused the p0a37.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    Did the shop install a Toyota pump? There have been all kinds of reports that many aftermarket (non-Toyota) pumps have poor reliability.
  15. Tombukt2
    13,885
    2,521
    Durham NC
    That's a lot of trans fluid coming out of they're. When the fill plug comes out and the car is level nothing should come out of the fill plug It's kind of like checking the rear end gear oil on her car or truck rear axle. Having four quarts come flying out of the fill hole at its removal generally the car would be slightly lifted up during this operation that most places so now level the car how much more came out That's how you want it to be when you replace it when the car's level nothing should be coming out of the fill plug if you were to stick a pipe cleaner or something like that in there It should just be touching the fluid at the bottom of the threads of the fill plug hole. All that extra fluid could be some of your problems.
  16. Joshua Gaynor
    Rhode Island
    Above link is another individual who had an overfilled tranny; it caused P0A37 just like you. This is most definitely your issue.
  17. bisco
    52,927
    how can they get an extra 4 qts in there?
