2008 Prius- P3190, C1242, C1241
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gvlgvkhg, Mar 9, 2023.
  1. gvlgvkhg
    gvlgvkhg New Member
    Kansas
    The engine on my 2008 Prius cutout while driving on the highway, check engine light, red triangle light, ABS light, brake light etc. all came on. Would not start back up initially, but after sitting overnight the engine turns on for about eight seconds then cuts off. This all occurred within 48 hours of getting an oil change, never had any issues like this previously. When a diagnostic was run I got the codes P3190, C1242, and C1241. Any feedback is appreciated.
  2. JC91006
    16,671
    8,516
    Did you check if the oil level was correct? Are you out of fuel? The 8 seconds is not the engine starting, just the HV battery spinning the engine.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,954
    1,905
    NJ-USA
    P3190 is the ECM reporting that the engine doesn't produce as much power as expected. The other two codes are the ABS ecu not liking the voltage at one of its power input feeds.
    As mentioned, the car will spin the engine at 1000 rpm for up to 10 seconds when it tries to start it. If you try too many times you will run the High Voltage battery down - it's not easy to charge that if the car won't run.
    Typical causes for P3190- out of gas, failed fuel pump, dirty throttle body, dirty MAF sensor.
    You might want to put a "smart" (AGM compatible) charger on the 12V battery. Turn the ignition ON (power button x2 but no foot on the brake pedal). Then use a digital multimeter to check for power on both sides of all fuses - both in the underhood and underdash fuse blocks.
  4. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Did you need help finding the related workups for the above OBD2 codes (DTCs), or are you able to find them via the builtin search feature?
    FYI : you're moderated until you've posted 5 times.
