2008 Prius Touring Aux Battery needing replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by frelynne, Nov 25, 2011.
  1. frelynne
    frelynne New Member
    North Highlands Ca
    Has anyone had to have their aux battery replaced
    I have an 2008 Touring car and the battery is over 31/2 years old but not 4 years old yet and the day before Thanksgiving I had to have the aux battery replaced cost with labor and tow was $327.00
    Would have thought the extended warrenty I paid for when I purchased the 2008 Touring car would have covered that but it did not
    Anyone else have this problem my car is not that old yet
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Welcome!
    I'd venture that half the Gen II owners registered here have replaced the 12V, either proactively, or due to failure like yours. It is the #1 source of problems.
    Typical dealership replacement starts at $225, so $327 is a little steep.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I replaced mine on my 06 in Feb 2011 w/an Optima Yellow Top. You could've DIY for cheaper...
    Out of curiosity, what dealer did you buy your Prius from? Only reason why I ask is because I hope it wasn't Roseville Toyota or another dealer following such poor practices (http://priuschat.com/forums/gen-ii-prius-technical-discussion/100011-closed-minds.html). Running the factory 12 volt until it's totally drained is bad for it.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    You guys with cars years younger than mine replacing your 12V batteries is starting to worry me. I'm still on the original with my 2006 (68k miles).
    I've been thinking that I should top off the battery with some distilled water. Anybody else gotten the thing apart enough to do that?
  5. Patrick Wong
    18,210
    6,517
    If your original battery has the traditional wet cell construction then that would be fine. However if your original battery is AGM that would be a good way to kill it for sure.
    After the battery is removed from the car you can shake it to see if you hear fluid, or shine a light through the translucent white case and tilt it to see if you can find the fluid level in the battery. Those would be a couple of ways to identify whether it has wet cells or not.
    It is easy enough to use a single-edge razor blade to peel off the top label (which contains a printed warning not to remove it) which exposes the rectangular translucent plastic cover over the six cells. Then you can remove the cover and look in to see whether your battery is AGM or not. If you see fuzzy white mats separating the lead plates, the battery is AGM.
  6. tommymommy
    tommymommy Member
    120
    These are sealed batteries. No place to top them off. I replaced the OEM batteries in both my 06 & 07 in September. It was not hard at all and took about 20 minutes per vehicle. I used the Optima yellow top from elearnaid.com. It comes with fairly easy to follow instructions. $360 for two batteries with kit. The terminal posts are larger in diameter than the stock Toyota battery. The kit contains the connectors for these posts. Follow the directions & you will be fine.
  7. 2Nutz
    2Nutz New Member
    S.F. Bay Area
    Just did this to my '07 w/ 115k. As Patrick said, take it out, peel off the label, take out the clear strip covering the caps and then pop off each little rubber cap. Unfortunatley on mine, the battery is Not clear but a black case, ie. can't see through it to get an accurate level indication. On mine, three of the six cells were below the top of the inner plates as far as fluid level. Added distilled water to bring all 6 cells up, reassemble and back in business. Was done about a month ago, no issues.
    Just be careful not to lose the little rubber caps and pay attention to fluid level if you don't have the exterior markers on the case. Do Not fill up to the top w/ water.
    Oh ya, cost = 0 (Already had the distilled water).
  8. Ynot1951
    Ynot1951 New Member
    Wisconsin
    Replaced the aux battery in my wife's 2007 Prius last year - dealer - battery was ~$130 I think - labor $45 - (had the battery exposed - must have taken them all of 5 minutes) and misc changes of $22 = total about $200. Could have easily swapped the battery out my self. Original lasted about 3.5 years - not sure how long it was on the lot.
  9. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    I'm still on my original (also a 06) with 190,000kms (118,060 miles).
    I think I'll replace it next spring if it makes it through the winter.
    So far, nothing has been done to the car other then oil changes, transmission fluid changes and an alignment and tires.
  10. volcomholls
    volcomholls Junior Member
    28
    Wilmington, NC
    2024 Prius
    I just replaced mine last week, at just under 80,000. The check engine light came on, and the dealer said that was the problem at $320. 40 miles later, the CEL comes back on.
    I didn't believe it was the battery in the first place. I had one issue with it starting in the dead of winter last year, but after the boost I haven't had a problem. CEL never came on then.
    Anyone else experience a CEL with aux battery problems?
  11. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    It is most often the underlying cause of ABS/VSC/TRAC lights.
  12. spandana
    spandana New Member
    Colorado
    I have a 2006 Toyota prius which needs auxiliary battery replacement. It was working fine until one day it all freaked out and would not start, dashboard lighted up. After jump starting it has been working fine but dealer said it needs new battery.
    How easy is it to replace the battery in trunk? Can you buy this battery and do it yourself?
  13. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
  14. richard schumacher
    7,682
    1,064
    United States
  15. tbradway
    tbradway Junior Member
    cary nc
    Just replaced my aux battery with a werker agm sealed battery model wka12-55c/fr
    From batteries plus $126 plus tax The 33 amp modl was same price. It was. Tight fit but went in no problem . Battery has threaded fittings and comes with about a 1/4 inch bolt.
    Removed prius battery positive clamp and bolted the black fusible link box right to the positive terminal with a small washer underneath to bridge the space in the bracket. Bought. Ground strap for the negative side that had two bolt fittings instead of the prius clamp. Did not want to modify any of the prius hardware. Case i want to revert back to stock battery.
    Hope it lasts 5 or 6 years.
  16. captnslur
    captnslur Junior Member
    78
    Lake Crystal, Minn
    I have an '06 and I replaced my 12v with a dealer purchased Toyota battery - cost $138 and by using a booster battery hooked up under the hood, I switched out the battery in about a half hour and didn't loose any radio settings etc.
    Very easy. I was surprised the dealer battery was so reasonably priced. I paid about $115 ( at Batteries Plus) for the 12v in my Miata - same sort of rear mounted vented battery.
  17. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    tbradway, thanks for posting this. There has been much discussion lately since Britprius (John) started researching this alternative for the Prius. The problem we have run into in the states is finding specific mobility battery alternatives, which seem to much more resilient than the OEM and typical replacements, is the needed venting that allows a tube to direct possible gases out of the vehicle. Does your selection have accept the Prius tube or allow for the installation of a replacement?
