2008 Prius traction battery failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jason Joe, Jan 25, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    We have had just a few 2008 batts die so far...but they are due to start failing this year. Sounds like OP bought a 2008 model in late 2007 so his 8-yrs is up on the warranty. So Toyota kindly assisted. One of our repair members here just said yesterday 75% of his batts replaced in 2015 were 2007 models.
    With the brake problems I am having on my minivan (apparently generic issue due to auto makers making cars bigger but keeping brakes smaller) I am reluctant to get anything except a hybrid with regen braking.
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Good question Jim.
    The basic theory is that limiting the range of usage to approx 40% to 80% helps prevent any cells getting overcharged or overly discharged (even reverse biased), particularly as the pack starts to age and the cell characteristics and cell balance inevitably start to diverge. It also prevents operating in the range where charging is likely to cause excessive heating of the cells.
    Trying to improve the pack balance by "over charging and super discharging" as you call it, is only done occasionally, and most importantly, done at considerably lower current than that of normal operation.
    I hope that helps. :)
    S Keith and m.wynn like this.
  3. Former Member 68813
    3,524
    983
    US
    Hybrid-related components, including the HV battery, battery control module, hybrid control module and inverter with converter, are covered for 8 years/100,000 miles.
    What hybrid warranty coverage do I have on my Toyota?
  4. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Except in CARB (California rule) states where it is 10 years/150k miles.
    JeffD
  5. Jason Joe
    Jason Joe New Member
    Tx
    I live in Texas the 10yrs 150K only applies to CARB states such as CA
    Yes I am a daily driver. In the 2 years I have owned it I have put another 47K on it. We get weather here in TX so I also have a highlander I switch back and forth on. I'm not exactly sure what the previous owner but they put around 8K a year on it and I did learn that lower mileage isn't always the better option. I parked this car for 3 weeks when the blizzard hit us, and within that 3 week period went and started the vehicle and let the ICE run for about 20 mins (MAX heat)... from what the forums were saying. At that time there were no warning signals or anything on and vehicle was running fine. I go back on the 4th week to change back to the Prius and all these warning lights come on. At first I thought it was the inverter water pump but then Toyota plugged it into a computer and it threw the P80 code which is the traction battery.
    #25 Jason Joe, Jan 26, 2016
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    I sure do wish we had you're old battery for testing because that code could have been stored as an intermittent code from a weak 12V battery. The end result for you was great but unfortunately, it resulted in some negative press from you about hybrids (which by and large is not the case). I am very suspicious if your battery was even bad.
    What were the symptoms besides the lights? Was it driving fine? Was the HV battery fan on? Did it go from low charge to high charge in about 30 seconds? Did the engine rev high?
    If your battery was indeed bad, it would be an extremely rare occurrence since its an 08 with less than 100k miles.
  7. Jason Joe
    Tx
    Yes I besides the lights it was driving all from the ICE and the fan did not come on. The charge did go to the last 2 purple lines to fully charged back to just the blue lines. The engine did rev high. Did not drive it too fast to the dealership. I check my 12v battery voltage and it was holding a good charge. I am a little surprised myself to have not gotten any codes 2 weeks in starting it and then the 4th week hit with all these warning lights.
  8. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Got it! Thanks.
