2008 Prius vs 2003 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by sandysalad, Jul 21, 2021.
  1. sandysalad
    sandysalad Junior Member
    Bronx, NY
    2003 Prius
    I
    Hi everyone,
    One year old Prius owner here. Have a little weighing in to do and thought you would be the best community to ask!
    - I was gifted a 2003 Prius last year with 92K miles. Now it's at 95K miles (I live in a city and don't drive regularly). Replaced battery in 2018. No major issues whatsoever, except right now the a/c might be leaking into the front passenger seat...
    - My inlaws are offloading their 2008 Prius with 184K. Original battery, mostly highway driving. No major repairs, the O2 sensors need replacing (but my 2003 doesn't have them so I don't really mind). The timing cover is currently seeping oil, as per a service in June.
    - My inlaws are in California so the car would need to get shipped across the country to me. Adding a cost.
    My question is: Do I trade-in my 2003 with 95K miles and excellent condition for a 2008 with 184K, also in what seems to be good/excellent condition? I do 80% city driving (very occasional trips to the suburbs), just looking for longevity, reliability, low maintenance.
    thank you all!
    52,876
    you're kind of iffy with either, but if you're happy with the service you are getting on the 03, i would stick with it.
    usually the biggest challenge is finding qualified echs.
    08 is ore common and a great vehicle, but reliability cannot be guaranteed as it heads into the back nine.
    in either case, used cars are quite valuable, and you or your in laws should look into selling one of them.
  3. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Because used cars are selling for a high price right now you could do really well on selling your 2003, especially if you replaced the hybrid battery with new rather rebuilt. Just do the transaction with a private buyer in the parking lot of their bank where's there's lots of security and cameras around. Hold out for the highest price too!
    And the 2008 will be a really enjoyable upgrade for you... And if your inlaws still have the original catalytic converter on the 2008 and odds are replacing the 02 sensor won't fix it but replacing the catalytic converter will, then you can by a cheap $200 aftermarket cat and sell the old clogged cat to a precious metal scrapper for $1500 cash.
    It's pretty rare that buying and selling cars in the 13-18 year age range could actually be a money making opportunity, but if you can get a family discount on the 2008 you could be very pleased at how it all works out in terms of the numbers.
  4. sandysalad
    Bronx, NY
    2003 Prius
    I
    Thank you all for the advice. My in-laws are actually offering me the 08 as a gift! I would just have to pay to ship it out. Very generous of them. They are just gonna trade it in if I don't take it. Apparently the KBB value is only around 2K for it, which is crazy.
    I believe there is the original cat converter. But, they are getting stolen a lot in my area... my 03 doesn't look like a Prius so I think it's been spared...
  5. PriusCamper
    13,468
    5,438
    The cat on that Prius will cover your shipping costs... And if you can find a friend who's great at driving and needs to travel from west coast out east you can lower the cost of shipping to the cost of gas at 50mpg. :)
  6. ChapmanF
    19,041
    Do you prefer a sedan or a hatch?
    I was very fond of the Gen 1. But it did have a couple of sensors built with potentiometers (the steering torque sensor and the go pedal sensor) that can eventually give you headaches if they haven't already, which were replaced with non-contact sensor types in Gen 2.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Almost certainly the evaporator drain line. Most likely it is blocked near the exit under the car, remote chance there is a hole in it under the carpet. If it is in the same place as other Prius models if you pull up the carpet in front of the passenger seat you will see a clear tube with a junction. Pull it apart at the junction and blow out the distal part from the inside (so you don't push crud up into the evaporator).
    Regarding which is a better car, since one is in NY and the other in CA I would investigate the rust situation. It is highly likely that there is a lot of rust on the bottom of a car which was driven on salted roads every winter. (You don't drive it much now, but some of those 92K miles were under those conditions.) Conversely, the CA car, assuming it was always there, probably has at most a bit of surface rust on the bottom.
  8. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    The 2003, from what I remember (owned one for a couple of years way back when), is much more uncomfortable.
    There is no middle armrest (or it is in an awkward position, again, if I remember right).
    It is more like low 30s in miles per gallon department (vs. the gen 2 getting low 40s).
    It looks old and it is not a hatchback.
    Both are reliable but it's more about comfort/looks/space between the 2 and I would say the gen 2 is the winner.
    I drive mine every day and it has 272k miles. Really haven't done any maintenance since I hit 200k and did struts.
  9. ChapmanF
    19,041
    Also, Gen 1 had belt-driven A/C. If you're stopped with the A/C turned on, the engine will cycle on and off really often (and you'll notice the air warming up every time it's off).
