2008 Prius will NOT move + Code P0A90 Drive Motor “A” Performance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriuSocal, Apr 21, 2025.
  1. PriuSocal
    PriuSocal Member
    202
    SoCal
    Thanks @James Analytic for your input. I assume the code may be due to the damaged wire to the motor temp sensor itself as it would cause it to not read properly. I have checked all the plugs that were involved with the trans removal itself and double checked prior to installing the inverter which has most of those plugs running underneath it and all was reconnected as it should.
    Let’s hope repairing this broken plug takes care of some of the codes that are causing that red car with exclamation point.
    James Analytic likes this.
  2. PriuSocal
    PriuSocal Member
    202
    SoCal
    Update:
    Went to the junkyard, got another motor temp sensor pigtail, removed the red wire along with the connector and installed it on my existing plug. Appeared to have worked, red car with exclamation point is gone, along with it all the others except the TPMS (may be due to it having a spare tire in the rear) and the C1378 Capacitor Comm Malfunction code. I have not been able to actually drive the car as it needs an alignment after replacing all the front end suspension components. I did however mode it back and front in the driveway and appears well.
    I tried to erase the C1378 code and it will NOT erase, stays as current. Any idea as to what this could be? Prior to the transaxle swap, car did NOT have any codes except for P0A90 and P0335 codes but both are gone now. I wonder if it just needs to be driven or something reset a specific way that this AP200 scanner cannot. ABS light in NOT on.
    Is the this code calling out the Brake Control Power Supply? And, is this unit the black box near the 12v battery which has 1 or 2 connectors going to it?
  3. ChapmanF
    18,213
    Yes and yes.
    Often, that code pops up when someone has done work back there, and the 1 or 2 connectors didn't get reconnected all happy-like.
    Maybe not the explanation every time, but one can hope.
    PriuSocal likes this.
  4. PriuSocal
    PriuSocal Member
    202
    SoCal
    Thanks for the clarification. And, yes I had to remove this unit in order to remove the battery when I did. I recall plugging it back up but just found this other post here Trouble Codes C1377 and C1378 | PriusChat and he OP mentions the unit needing to be grounded to the body so reinstalled properly I guess. What the OP does not mention in his fix is if the grounding part was the issue causing the code or the replacement of the BCPS unit.
    Will check and report back. Thanks!
  5. dolj
    dolj Senior Member
    8,448
    4,291
    Wellington, New Zealand
    If your BCPS is not bolted down, then that would be the first thing I'd do. Grounding is via the connection points.
  6. PriuSocal
    PriuSocal Member
    202
    SoCal
    The BCPS was not plugged in, I inserted the plug and code has gone away. The one I recall moving was the box attached to the positive cable not the BCPS but glad I found it unplugged and it was not an issue with the braking system as I was alarmed it would be the ABS accumulator since I replaced it 2 years ago when I bought the car.
    Car only has the TPMS light on but im almost certain its the spare tire which I should be fixing this weekend. Excited to do the 1st drive after the alignment.
    James Analytic and Brian1954 like this.
  7. James Analytic
    331
    52
    Michigan
    Awesome! I recall Walmart at some locations will pair the TPMS for free. Maybe Discount and Belle Tires at some stores. Both will check to confirm at least in my experience, as well as most other tire shops.
  8. PriuSocal
    PriuSocal Member
    202
    SoCal
    I officially took the prius out for a drive today and I drove about 50 ft away when I pressed on the brake and heard a grinding noise. It sounded like it was coming from the middle like underneath the floor hump thad divide driver and passenger sides. If I braked gently no sound and no sound while driving only when I braked hard. I initially thought I may have left something like a tool or screwdriver underneath but no, looked under and nothing. I kept driving normally and accelerated/decelerated normally and good just that grinding sound. The best way I can describe it is like when brake pads are worn out and riding on the disc (but not my brakes). I got home and lifted the car and checked all the bolts like Subframe, brakes, struts, ball joints, trans mount and rack and pinion and all is tightened to spec and nothing seemed loose. Additionally, brakes are good with lots of life left.
    The more I drove the car, the less I hear it. Now I will hear it only if I press on the brake hard to come to a stop but not if I brake normal meaning regular freeway or street MPH.
    I have posted a video for you to hear it, sorry that the 1st brake you will also hear my tools fall off the seat but clearer the 2nd time I brake. Not sure if its the best sound quality but lmk and I can shoot another video - YouTube
    Any Ideal what that could be?
  9. dolj
    dolj Senior Member
    8,448
    4,291
    Most likely, surface rust accumulation on the rotors.
    If that is what it is, you should be able to clear it by finding a quiet stretch of road where you can accelerate to 40 MPH, shift to N, and then apply the brakes quite aggressively. Rinse and repeat until the 'grinding' noise is gone. It should only take four or five goes.
    Let us know the outcome.
    Brian1954 likes this.
  10. ChapmanF
    18,213
    For some reason, I never seem to need to do anything as aggressive to rub off surface rust. I usually hear it right away pulling out of my driveway if there has been rain recently, and I just rub it off by shifting to N before stopping at each of the 3 stop signs on my way out of the neighborhood. Just driving normal neighborhood speeds, not 40 mph or anything, and just braking normally, except in N. If I have a passenger, they rarely notice I'm doing anything special, unless they see me shift to neutral.
    The rotor rust grinding noise, it generally lasts as long as you are rolling with the brakes applied.
    The noise in your video, it kinda sounded like it had a definite length, like, it lasts just that fraction of a second long and then it's done, even if you're still braking, still rolling.
    One noise that can be like that is the fluid whoosh if there is a bunch of air in your lines. I'm not saying I'm sure that's your noise, but you might try and see if it behaves that way. You can usually catch it in the act even when you're braking gently: you just hold the pedal gently down so the car gently slows, normally all by regen until you reach the 6 mph or so transition speed and the car tries to then smoothly switch from regen to friction. But because of the air in the lines, it can't reach the right fluid pressure to take over from the regen without letting a quick loud whoosh of fluid into the lines. So you hear this quick whooshing sound right as you cross that 6 mph or so speed, just a fraction of a second and done.
    If that's what the sound is, you can usually get rid of it for a pretty long time by getting a bottle of fresh brake fluid and using a scan tool to go through the long-form bleed procedure, using the new fluid to make up for whatever you bleed out so the reservoir level doesn't drop.
    Maybe that's not what your sound is ... I just didn't think of anything else it reminded me of.
  11. PriuSocal
    PriuSocal Member
    202
    SoCal
    @dolj The sound is Def NOT coming from the rotors, they are clean and not rusted. It is generated from what could be behind the engine at bottom. Surface rust on a rotor sound would be present at any roll and light braking, this grinding only happens at hard braking and is much more like 2 metals grinding on each other. HOWEVER, it now takes a more aggressive push on the brake to hear it. Best way to explain is, let's say the brake pedal is at 0% when NOT pressed and 100% full pressed….the noise happens if I apply pressure all the way to 75-80% and now grinding so slight even at that.
    @ChapmanF I agree with the rotor grinding due to surface rust and I drove the car again as mentioned above and the more I drive the harder I have to press the brake to get it to grind. If I drive normal, the noise is NOT present at all. I exited a fwy off ramp at 65 mph and had about 100 ft to stop and applying the brakes as I would on any car will NOT make the grinding sound. A buddy of mine suggested the recently changed ATF making its way around the transaxle hence the noise beginning to decrease but, I believe I would hear grinding at other points of the drive not just braking.
    Additionally, I found this info on the web about the noise CV axles could make if bad:
    3. A humming or growling noise.
    This can be due to inadequate lubrication in either the inner or outer CV joint caused by a damaged or split boot. However, this symptom is more often due to worn or damaged wheel bearings, a bad intermediate shaft bearing on equal length half shaft transaxles, or worn shaft bearings within the transaxle.
    I personally did have the issue with the pass side cv axle as mentioned in one of the recent posts above, where I thought the snap ring on the inner shaft was bad but ended up being a damaged spline on the shaft that would not allow the ridges to mate when inserting it into the transaxle. I would say the noise matches the approx location of the inner axle head. Could the cv axle be the issue? I am pretty paranoid that it would be the replaced transaxle itself but hopeful due to it not making noise or is not shifting improperly. I wish I had a gopro or something to attach to the car while driving to see whats going on down there. I also read someone else said to put it on jack stands and attempt to hard brake on neutral without the wheels to see if it does this without load. I also replaced both front strut assemblies but they seem good.
    #71 PriuSocal, Jul 2, 2025
  12. PriuSocal
    PriuSocal Member
    202
    SoCal
    I checked the cars suspension on both sides and removed it (brakes, rotors etc) and checked all the tie rods, ball joints and retorqued to spec and cleaned/re-greased and was able to notice that the transaxle on the driver side had play back and forth when moving the car back and forth at park. I went up top and looked behind the inverter and noticed the mount moving when force applied. Took the inverted out and sure enough 2 of the 3 nuts where lose (14mm) and the 12mmm bolt was missing so caused the transaxle to sorta move at acceleration and deceleration. I torqued to spec, test drove the car and still no change, still has the grinding noise when I practically “slam” on the brakes only and it's very short.
    Still haven't resolved it and perhaps thinking that it may be the cv axle that may be causing this grinding where it goes in to transaxle and the snap ring.
  13. PriuSocal
    PriuSocal Member
    202
    SoCal
    On a side not not sure whats going on but car tend to be giving me weird “pending” codes. I have connected my Autel AP200 to the car a few times to check on the TPMS issues I am having and it has shown me 3 separate “pending” codes with NO check engine light. The 1st time was a p0335 crankshaft pos sensor, I cleared it and has not shown back up. 2 days ago I decided to run a diag just for kicks and it showed me a p0420 Catalyst below threshold code, i cleared it and it was gone. Today I ran another diag and now I am getting a p1116 Coolant Temp Sensor Circuit Stuck for Coolant Heat. I did a quick search on the code for a 2nd gen and came back to checking coolant levels to inverter coolant pump to replacing the sensor itself to replacing the whole 3 way valve.
    1. I have checked coolant levels for both ICE and Inverter and both are topped off at Max levels (no coolant leaks)
    2. Inverter pump is working and coolant is seen flowing when opening the inverter coolant reservoir
    3. Visually inspected 3 way valve and no leaks or damage is seen
    I also read that this code is nothing to worry about perse BUT it is annoying that random codes are popping up on the car and when cleared, a new one comes up. Could this just be a glitch? After all the CEL hasn NOT come one once for any of the codes and only way for me to tell is when I put the scanner that shows it a “pending”
    Any help would be useful.
  14. Brian1954
    Brian1954 Senior Member
    2,208
    867
    South Central PA, USA
    All pending trouble codes will not turn on any warning lights. If a pending code changes to a current code, a warning light may be turned on, but not all current trouble codes activate a warning light.
  15. dolj
    dolj Senior Member
    8,448
    4,291
    Pending is when all the conditions for the fault have not been met. Therefore, no light. By clearing the codes prematurely, you interrupt its monitoring of the condition.
    Pending codes are not something to worry about, but you should monitor. It is also possible that the final condition or conditions are not met, so the pending code could be cleared by the ECU.
    Finally, clearing codes does nothing to fix anything, so unless you actually fix the problem indicated by a code, you should not be clearing them.
    One exception, though, if initially faced with a wall of codes and you have no context and/or the codes together do not seem to make sense, you might clear the codes, run a few drive cycles and then scan the car again. The resultant codes, if any, are the ones you should focus on.
    You can use active tests to cycle the 3-way valve to see if it responds correctly.
    Your information in regard to the P1116 is incorrect. It is not about the functioning of the 3-way valve, it is to do with the temperature sensed on exit from the coolant heat storage (CHS) tank.
    You need to get access to the repair manual if you are going to work on these cars. The 'internet' or ChatGP (et al) are not reliable sources of information.
    #75 dolj, Jul 8, 2025
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    You are mostly correct.
    Some codes are "type A" codes. These have severe impact on emissions and will activate the MIL when the fault occurs. Also called "1 trip codes".
    Other codes are deemed to have less severe impacts on emissions. These are "type B" codes. The first occurrence will set a pending code in memory but no MIL. If the fault happens on the next drive cycle (under similar conditions), then the MIL will activate. These are called "2 trip codes".
    PriuSocal and Brian1954 like this.
  17. PriuSocal
    PriuSocal Member
    202
    SoCal
    The reason for me clearing codes is that a recent transaxle swap had some prior codes and after installation some new codes came up and wanted to ensure those issues causing the codes were resolved.
    As mentioned above, since clearing “pending" codes the last 3 times a new one has popped up and old codes have not returned and I am driving the care daily now to see how it all performs.
  18. dolj
    dolj Senior Member
    8,448
    4,291
    Apart from these type A/B emissions codes, there are many more codes where more than one condition needs to be satisfied and sometimes some of those conditions need to be satisfied over two or more drive cycles (2+ trip codes). These become pending while waiting for all the criteria to be met.
    I suspect that those codes that initiate and go pending but fail to meet all criteria after so many drive cycles, go to Hist. Maybe, there is a classification system where some are just cleared and some go to history. I'm just guessing about that, so take that with a grain of salt.
    #78 dolj, Jul 9, 2025
  19. PriuSocal
    PriuSocal Member
    202
    SoCal
    Yes, I agree.
    I have not deleted the p1116 code but glad the P0420 code has not returned and perhaps car is still settling in after all the work done to it. The mpg is not as great as before, I did switch to 195’s and dont really like how they look on the car. I thoight 195 was the width and not the height. I had read that also causes MPG drop but before I sold it to my brother it was getting 49-51 mpg and now its slowly climbing up but at around 40-41 mpg now. Although the HV battery works and charges fine, it may be winding down as the motor feels very good and healthy even at 280k ( Car was always maintained at dealer prior to me) but feel the car runs good when battery is at green but a bit sluggish at blue.
    I am getting an OEM 3 way valve from a local person just in case. Its good to have since its prone to going bad, I already have 3 inverter coolant pumps on deck too lol
  20. dolj
    dolj Senior Member
    8,448
    4,291
    I'll redirect your attention to what i said back in post #75:
