2008 prius will only stay in ready mode for 5 seconds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lynda Musselman, Apr 1, 2024.
  1. Lynda Musselman
    Lynda Musselman Junior Member
    Pennsylvania
    Brought this car home today. We were told the 12v and hybrid batteries have both been replaced. It had no codes when checked with a generic code reader. Started fine 3x. The 3rd time we drove it home. It was about a 90 min drive. Had zero problems. Parked it at home and maybe a half hour later my son went to take it out for an errand and he got maybe a mile before the car lost power and went out of ready mode. We disconnected the 12v for 2 min and now can only get it to go into ready mode for 5 seconds before it gets kicked back out again. The engine does come on in those 5 seconds. I've tried looking for this problem online and haven't found much info. Any help would be appreciated.
    Thanks
    52,830
    any trouble lights?
  3. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Even though it sounds like the engine started it did not. The ECM is trying to start the engine by spinning it using the electric motor/generator, but it does not detect any power from the engine within the time specified, so it aborts the attempt. If you scan for codes you may find a P3190, P3191, or P0A0F.
    The bad news is, that there is a finite number of times you can do this before the hybrid vehicle (HV) battery runs out of juice, so you need to fix the problem before trying to start the engine again.
    There is a scenario where the car goes dead while driving which is caused by the AM2 fuse blowing due to the inverter coolant pump shorting out. You could test out this possibility by disconnecting the inverter pump and then replacing the AM2 fuse. You can disconnect the inverter pump by unplugging the connector shown in the attached photo.
    Location of the AM2 fuse:
    Location of the inverter coolant water pump:
    You might also be able to check the pump by putting the car into IG-ON (two presses of the power button without your foot on the brake pedal) and looking into the inverter coolant reservoir to see if you detect coolant moving.
    I hope some of that helps.
  4. Lynda Musselman
    Pennsylvania
    The fuse looked like this. I didn't see the coolant moving at all.
  5. Lynda Musselman
    Pennsylvania
    None before this happened.
  6. Lynda Musselman
    Pennsylvania
    None at all. It just stopped.
  7. Lynda Musselman
    Pennsylvania
    The only thing we did do, between the time I bridge it home and the time it was driven next, was plug a phone into an aux cord that was already in the car.
  8. bisco
    52,830
    you can get the trouble codes read at a dealer, hybrid shop or buy your own
  9. dolj
    dolj Senior Member
    8,640
    4,391
    With the fuse in place or removed?
    The pins don't look good, but hard to tell just by looking, particularly as the fuse itself is out of focus. If you want to be thorough, you could test the fuse with an ohmmeter, but really, just replace it ensuring you have disconnected the inverter coolant water pump beforehand. I would also inspect the slot into which that fuse goes, and make sure it was clean of any corrosion and the like.
    I'm confused by this statement. What do you mean by, "between the time I brought it home and the time it was driven next". Has the car been driving since it just suddenly stopped while driving?
    If there are lights on the dash now, you should get the car scanned (using a capable scanner that can read all of the 11-14 computers). You could then post the results of that here which would be most useful.
  10. Lynda Musselman
    Pennsylvania
    We got it going long enough to get a p2102 code
  11. Lynda Musselman
    Pennsylvania
    I parked it when I got home and my son went to take it for an errand. We did get it running today after replacing all the engine fuses long enough to get a p2102 code.
  12. bisco
    52,830
