2008 Prius with heating issues and intermittent Red Triangle indicating overheating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Islanderfan17, Mar 3, 2025.
  1. Islanderfan17
    Islanderfan17 New Member
    Long Island, NY
    I have an 08 Prius with 160k miles. This winter, I started having serious cabin heating issues. The cabin heat basically stopped working but would occasionally work about 20-25 minutes into driving, and this was often including "warming up" in my driveway for 10-15 mins before driving. I had a check engine light on for awhile indicating, if I remember correctly, that it was probably the three way valve or inverter. One day on the way home from work, I got a red triangle of death and the car basically slowly lost power so I pulled on the side of the highway and the car would turn on but not move. Eventually I solved this issue I believe by disconnecting the wire for the inverter (I think?) above the fuse box and replugging it back in. I got the car working enough to get home and decided it was time to try and fix whatever was going on.
    For what it's worth, I previously had an issue like this years ago that happened on a trip back from Buffalo (8 hour drive for me) where it seemed the car was overheating and shutting down. I had to spend that whole trip back by driving a little bit, stopping somewhere and letting the car cool off, driving a bit more etc. til I got home. We replaced the three way coolant valve if I remember correctly and the issue went away but I often wonder what damage I did to my car on that drive home.
    So finally I decide I'm going to fix this via process of elimination if I can. I bought an OEM or OEM equivalent part (Aisin) for the Inverter pump and the three way valve. I installed both of them, no problem. Drained the coolant when I did it and refilled the coolant with the airlift system to make sure air bubbles wouldn't be an issue. Still, no heat in the car even when letting it sit on for awhile with the heat going. Next step was the thermostat, I removed it and put a new one in. The old one actually was working, confirmed with a boiling water test, so it definitely wasn't the issue. Then I tried the heat again, of course nothing. I had a code p1150 also at this point, which I read could be the coolant temp sensor, so I replaced that (easy job, though I had to re do the coolant again). Once again, nothing as far as heat.
    So today I decided to try and take the car to work just to see how it would do. First of all, heat DEFINITELY isn't working at all in the cabin. I drive about 15 mins and start getting an intermittent red triangle accompanied by the red thermostat looking signal on the screen to go with it. From what I've read, this means the system is probably overheating? So now I'm at a loss. Is it a head gasket issue? Is my coolant system clogged somehow? I really have no idea and I'm hesitant to sink more money into troubleshooting, I want to find the definite cause of it honestly. My wife has an 04 Prius with 130k miles we were going to sell (It has some weird quirks like a slightly crooked steering wheel, missing the radio dials, cruise control doesn't work etc.) but the heating in it works PERFECTLY and quickly, the cabin heats up within a few minutes. It needs a new catalytic converter and at this point, I'm considering just swapping the converter and radio from mine into hers and then selling mine but if it's a fixable issue, I'd much rather keep mine tbh. lol. Anyways, any insight or tips on this issue is very welcome, I am desperate at this point lol
  2. ChapmanF
    19,060
    A few things. The loop of coolant for cooling the engine and the loop for cooling the inverter and transaxle are totally separate loops, with their own separate reservoirs where you fill them.
    The heating in the cabin is part of the engine coolant loop. It's not connected to the inverter coolant loop.
    The inverter coolant pump, naturally, is part of the inverter coolant loop.
    The three-way valve, even though it's physically located right next to the inverter coolant pump, is part of the engine coolant loop, and not related to the inverter coolant loop. (Just follow the hoses. :))
    The three-way valve, if it gets stuck in a certain position, can block off flow to the cabin heater.
    The inverter coolant pump, if it stops working, can give you symptoms where the car conks out after a while and works again after cooling. P0A93 would be a typical trouble code for that. If you're not getting the trouble codes when warning lights come on, it would help to start.
    It sounds like there could be more than one problem with the car. Diagnosis gets extra tricky when that happens, but it helps to make a concerted effort to avoid mixing separate things up.
    Brian1954 likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Yes, your system is definitely clogged, the heat is not circulating, which means the engine is overheating and everything starts to circulate only through the thermostat.
    The three-way valve must work.
    If it is in the wrong position, the circulation system will be disrupted.
    A possible problem may also be a lack of coolant in the engine circuit.
  4. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    Check the coolant level in the radiator and in the overflow bottle. You need to remove the radiator cap and look into the radiator. The coolant level needs to be full all the way to the very top. I am guessing that it is not full. That would explain why you are not getting heat into the cabin and why the engine is overheating.
    Second point, you need to get a good OBD2 scan tool to read the trouble codes. Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    The Autel AP200 is a very good choice. It is $60 + tax at Amazon.
    #4 Brian1954, Mar 3, 2025
  5. Islanderfan17
    Long Island, NY
    I guess I'd be surprised because I re filled it using the Airlift vacuum system, which refills it to full as far as I know. It definitely did for my inverter system because it brought it perfectly to the full line on the reservoir.
    The three way valve was replaced and definitely installed properly. The coolant was drained and refilled. How would I go about finding a clog?
    #5 Islanderfan17, Mar 3, 2025
  6. ChapmanF
    19,060
    And, in case you never got the safety talk about radiator caps, there can be pressure under there if the engine has recently been on and not cooled down. You can usually get away with popping an overflow bottle cap any old time (a non-pressurized overflow bottle; don't do that with a degas bottle like gen 3 has).
    But the radiator cap on a hot engine could blow off as you loosen it and steam you in scalding coolant. Check when the engine is cooled.
