2008 Prius with new 12 V battery won't shift; lots of warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SuzyGS, Aug 20, 2017.
  1. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Techstream is only $15 for a month, so not much of an issue.
  2. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Glad you found that to be the issue, it is strange, I have recently had the same codes and issues, today just inspected battery and have 3 cells that are 5000amh but overall used but well within acceptable at this point. I however noticed after the test and clearing the codes twice. I tried to drive and right off the bat I hear a click (like the motor trying to start) and then it threw the error codes. I will go back and check the temps and see if that was it, locally its been in 100 and the garage I was working in it was 105 at the time. (n) So far all the failures come around the heat.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    It’s more than $15 for a month for Techstream :cool:.
    It’s $20 for 2 days;).
    And probably around $100 for a month. But I haven’t looked recently, but it was north of $70 the last time I was on the techinfo website(y).
    SFO likes this.
