2008 prius won't move. brand new OEM battery tested good all gears flashing on dashboard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ryanz1, Jun 23, 2022.
  1. ryanz1
    ryanz1 New Member
    united states
    2008 prius won't move. brand new OEM battery tested good all gears flashing on dashboard.
    Can't Find a single post on the internet about this issue.
    battery is confirmed good by auto center.
    Press POWER on. all accessories come on. very bright dome lights. menu signal check reads 12.1. seems low to me for a OEM genuine battery $222.
    engine never comes on. Press brake pedal and Power on. all the gears P D R N start flashing car engine still not running and can't put into gear?
    Main battery dead? should still run on gas correct???? pulled and checked every fuse in car took about 2 hours.
    don't know how to check relays.
    HELP
    ryan
  2. PriusCamper
    PriusCamper Senior Member
    12,023
    4,885
    Pacific Northwest, USA
    Usually this is because the Orange Safety plug on the battery pack wasn't pushed all the way down...
  3. dolj
    dolj Senior Member
    8,202
    4,178
    Wellington, New Zealand
    It is. Charge that battery up to full (brand new it should be at 13.0 - 13.2 V) if you care at all about it lasting a good long while.
    Nope. Dead hybrid vehicle (HV) battery, dead car. Check the safety interlock as PriusCamper suggested. Although why you removed that (if you did) is anybody's guess. It is not necessary at all for a 12 V battery change.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    First things first. Which battery are you asking about?
    fotomoto likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,959
    1,907
    NJ-USA
    Hello and welcome to PriusChat. Now, what is the history of this car and the problem you're having?
    Is the car a recent purchase? Has it been sitting for awhile? When did it first have this fault or when did it last work correctly?
    Using the center screen (MultiFunction Display) to check voltage is not very accurate. A better way would be to use a decent digital multimeter at the 12V battery itself or at the "jumpstart" point in the underhood fuseblock.
  6. ChapmanF
    17,282
    If my memory serves, flashing PRNDB was pretty much reserved to indicate that the combination meter wasn't communicating with other ECUs like the HV control ECU (which is the one that knows what "gear" you've selected).
